Forum Topic - PORT IO functions in*() and out*() will deal with Physical Address or Virtual Address before the Kernel intialization starts?: (3 Items)
Hi OSTech,
in startup code initialization (before entering to Kernel initialization) the port IO fucinons  in*() and out*() will
work directly on physical addresses or virtaul address ?
Ravinder Are
Re: PORT IO functions in*() and out*() will deal with Physical Address or Virtual Address before the Kernel intialization starts?
Depends on the architecture. You should always do a startup_io_map() and
the return value from that will be the appriopriate value to feed into
the in* and out* functions for the system that you're running on.
From a theoretical standpoint, program code _always_ operates on virtual
addresses. It's just that if the CPU memory managment unit hasn't been
turned on yet, virtual == physical. As implied above, some architectures
have the MMU on during startup and some don't.
On Fri, Nov 26, 2010 at 05:31:55AM -0500, ravinder are wrote:
> Hi OSTech,
> initialization) the port IO fucinons  in*() and out*() will work
> Thanks,
> Ravinder Are
> http://community.qnx.com/sf/go/post76105
Thanks for the info
