Forum Topic - STOPPED: (10 Items)
STOPPED
Sometime when one of my program terminates normally, by returning from main(), it gets in a STOPPED stated.
What can cause a program to go into a STOPPED stated on its own?  I'm guessing is caused by a destructor of some C++
global object.
I can I kill a program in STOPPED stated.  Only solution I found is to reboot the computer.
Re: STOPPED
If stopped --- try hitting with with some death signal (SIGTERM, SIGKILL) followed by a SIGCONT.  I usually see this as
a result of a debugger trap.
Re: STOPPED
> followed by a SIGCONT.  I usually see this as a result of a debugger trap.
I think I already tried that but will try again next time it happens.
Re: STOPPED
I doesn't work. I hit the program with SIGKILL and then SIGCONT but nothing.  Only solution was to reboot.
Re: STOPPED
Comments?
Re: STOPPED
Hi Mario, sorry this slipped through the radar.
We do have a similar PR open on this one, it's on my todo list to get to it.
In the meantime, how reproducable is this?  Do you think it would be
possible
to capture a trace?
You could add an event handler for NTO_TRACE_THSTOPPED and do a
TraceEvent(_NTO_TRACE_STOP),
with the tracelogger in ring buffer mode.
Cheers,
Colin
SIGKILL)
trap.
nothing.
Comments?
OSTech
http://community.qnx.com/sf/go/post4459
<http://community.qnx.com/sf/go/post4459>;
cburgess@qnx.com <mailto:cburgess@qnx.com>;
Re: STOPPED
> possible
> to capture a trace?
I can try.  Unfortunately it's not reproducible, it seems related to some of the threads crashing. but when in stopped
state there is only one thread left.
At first I though it could be related to dumper, but I killed dumper will my program was in stopped state and that had
no affect.
> Cheers,
> Colin
> SIGKILL)
> trap.
> nothing.
> Comments?
Re: STOPPED
Hmmm, it could be related to process cleanup.    How often does it happen?
it.
> possible
> to capture a trace?
the threads crashing. but when in stopped state there is only one thread
left.
program was in stopped state and that had no affect.
> Cheers,
> Colin
> SIGKILL)
> trap.
> nothing.
> Comments?
<http://community.qnx.com/sf/go/post4459>; >
> cburgess@qnx.com <mailto:cburgess@qnx.com>;  <mailto:cburgess@qnx.com
<mailto:cburgess@qnx.com>; >
OSTech
http://community.qnx.com/sf/go/post4486
<http://community.qnx.com/sf/go/post4486>;
Re: STOPPED
I'm not sure cause it has happend for a while but I think it's because the process uses lot of ram (400Meg) and it
crashed on termination and is being dumped by dumper.
Given our usage of slow flash drive it probably takes a minute or 2 for the dumper to do its thing. Long enough for me
to get confused ;-)
I have fixed some bug on process termination which probably explain why I haven't see this problem for a while.
May I suggest a new process/thread state call dumper DUMPING.
Re: STOPPED
At least pidin should check the process flags for _NTO_PF_COREDUMP
> happen?
> the process uses lot of ram (400Meg) and it crashed on termination and
> the dumper to do its thing. Long enough for me to get confused ;-)
> http://community.qnx.com/sf/go/post4876
cburgess@qnx.com
