Forum Topic - fesh,esh output redirection problem: (9 Items)
Hello all,
"eecho Teststring >testfile" results in an empty file and the output string is printed to the console.
All (f)esh buildin commands seems to behave like this.
If you start a normal process from the embedded shell, redirection works as expected.
Is this a bug or a feature?
-Michael
Re: fesh,esh output redirection problem
See http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/f/fesh.html#eecho
It is a feature. Use regular echo if you want the other behavior.
Michael Tasche <community-noreply@qnx.com> wrote:
Hello all,
-Michael
OSTech
http://community.qnx.com/sf/go/post69139
> eecho
Well, I am fighting against a very small nor flash.
Other example:
# alias walter=uwe
# alias >testfile
walter=uwe
=> Output goes to console.
=> The file "testfile" is created, but empty.
For what we need this feature?
Perhaps you can explain that.
BTW:The "alias" example works as expected with the kornshell.
-Michael
 Currently neither esh/fesh support redirection for print/eecho or the
alias command.
Prior to performing file globbing if the command parser detects either
the '>' or '<' redirection symbols in the command line it either creates
an empty file for writing or attempts to open one to read from. This
explains the behavior you have observed so far.
While I know this doesn't quite answer your question as to why things
are like this but if we keep in mind that redirection is not supported
for those commands then adding redirection symbols in the command line
can be classified as unspecified behavior. Redirection support can be
added to those commands with relative ease though.
The Korn shell is a different shell and also was not designed with the
same requirements as either esh/fesh so not valid for the comparison.
>> eecho
> Other example:
> # alias walter=uwe
> # alias >testfile
> walter=uwe
> -Michael
> http://community.qnx.com/sf/go/post69180
> alias command.
Yes, I agree after looking at the esh source.
At the moment the "redirection feature for buildin commands" is not mission critical for my project, but I think this
feature would be very senseful for the embedded shell.
What do you think?
You are certainly free to add redirection support as the source code is available. I provide a rough diff that adds
support to most commands - you are free to use this but remember this is not a supported customization.
Attachment: Text esh.diff 3.24 KB
RE: fesh,esh output redirection problem
esh redirection works correctly for me in 6.5.0 M9:
#esh
#echo "this is good" >good.txt
#cat good.txt
this is good
>"eecho
I'm assuming you meant to write "echo" with one e.
-ad
From: Michael Tasche [mailto:community-noreply@qnx.com]
Sent: Thu 2010-09-30 08:14
To: ostech-core_os
Subject: fesh,esh output redirection problem
Hello all,
-Michael
OSTech
Attachment: Text winmail.dat 2.77 KB
Actually, eecho is a fesh built-in.  Whether the behaviour is expected
or not, I'm not certain.
> #esh
> #cat good.txt
> this is good
> >"eecho
> -ad
> To: ostech-core_os
> Hello all,
> works as expected.
> -Michael
> http://community.qnx.com/sf/go/post69168
Redirect support is not enabled for either print or eecho.
#esh
#cat good.txt
this is good
>"eecho
-ad
To: ostech-core_os
Hello all,
-Michael
OSTech
OSTech
