Forum Topic - x86 hyperthreading: (10 Items)
x86 hyperthreading
With 6.5.0 I tested the effect of enabling hyper-threading on performance and it's bad.  Seems the kernel doesn't know
that the extra CPU aren't real.
My testing shows that CPU 0-1 are the same, CPU 2-3 and so on. If I start a process with two threads, it's not much
faster then having one thread only as the two threads are allocated to CPU0 (real) and CPU1 ( hyperthreading). If I
start the program with
on -C0 and -C2 then I get the performance I expect.
Is there any option or way aside using "on" all over the place to make the kernel smarter about its cpu allocation?
RE: x86 hyperthreading
All the code i've seen indicates the kernel assumes all cpus are equivalent.
Sent: Thu 2010-09-23 13:34
To: ostech-core_os
Subject: x86 hyperthreading
OSTech
http://community.qnx.com/sf/go/post68407
Attachment: Text winmail.dat 2.74 KB
> -----Message d'origine-----
> De : Attilla Danko [mailto:community-noreply@qnx.com]
> Envoyé : 23 septembre 2010 13:38
> À : ostech-core_os
> Objet : RE: x86 hyperthreading
Thanks. Basically that means QNX6 doesn't really "support" hyper-threading on x86.
For some reason my selective memory remember that :
http://www.embeddedstar.com/press/content/2002/9/embedded5049.html
Cheers!
> To: ostech-core_os
> and it's bad.  Seems the kernel doesn't know that the extra CPU aren't real.
> process with two threads, it's not much faster then having one thread only as
> start the program with on -C0 and -C2 then I get the performance I expect.
> http://community.qnx.com/sf/go/post68409
Re: RE: x86 hyperthreading
Maybe that's because its called "symmetric" multiprocessing :)
Re: x86 hyperthreading
If the calculations can be split into multiple threads it's usually a good practice to start from as much to twice as
much threads as there are CPUs in the system. And this automatically solves your problem.
> De : Oleh Derevenko [mailto:community-noreply@qnx.com]
> Envoyé : 23 septembre 2010 13:49
> À : ostech-core_os
> Objet : Re: x86 hyperthreading
> to start from as much to twice as much threads as there are CPUs in the
Huh?  Say I run a program at priority 10 with 16 threads ( on an 4 core + 4 thread).  Then network stuff is happening at
 priority 20, but io-pkt and its threads end up being assigned to core 1-3-5, what will happen is that io-pkt could run
a 5% of the speed it's supposed to.  Not good.
> > start a process with two threads, it's not much faster then having one
> > hyperthreading). If I start the program with on -C0 and -C2 then I get
> http://community.qnx.com/sf/go/post68412
> practice
> thread).  Then network stuff is happening at priority 20, but io-pkt and its
> could run a 5% of the speed it's supposed to.  Not good.
Execution is preempted and execution time is assigned to threads in small time slices. That's why it does not have any
effect if once you'll have an unfortunate combination - the next time slice the threads could be assigned to completely
different cores. In general everything will be fine unless you explicitly bind your threads to bad core combination.
RE: RE: x86 hyperthreading
> Envoyé : 24 septembre 2010 05:34
> À : ostech-core_os
> Objet : Re: RE: x86 hyperthreading
> > > a good
> > practice
> > core + 4 thread).  Then network stuff is happening at priority 20, but
> > happen is that io-pkt could run a 5% of the speed it's supposed to.  Not
> good.
> time slices. That's why it does not have any effect if once you'll have an
Have you actally done this in real life scenario or your just theorising? What you are saying doesn't make any sense to
me.  Our machine has 8 core + hyperthreading thus 16 "core". Unless every  single operation  can be splited into 16
threads to keep everything busy, real-time goes out the window, big time.
> http://community.qnx.com/sf/go/post68473
Re: RE: RE: x86 hyperthreading
>  you are saying doesn't make any sense to me.  Our machine has 8 core +
> into 16 threads to keep everything busy, real-time goes out the window, big
> time.
Nobody was saying it is an easy thing to keep 16 cores busy with just a single application. In any case, if you can't
upgrade your hardware to fully independent cores you have to be prepared that a low priority thread while being
scheduled at the same CPU in hyperthreading mode with your high priority thread will make the latter execute slower. So,
 hyperthreading is not a realtime anyway.
RE: RE: RE: x86 hyperthreading
> Envoyé : 24 septembre 2010 09:22
> À : ostech-core_os
> Objet : Re: RE: RE: x86 hyperthreading
> > > small time slices. That's why it does not have any effect if once
> > theorising? What  you are saying doesn't make any sense to me.  Our
> > single operation  can be splited into 16 threads to keep everything
> application. In any case, if you can't upgrade your hardware to fully
> being scheduled at the same CPU in hyperthreading mode with your high
> priority thread will make the latter execute slower. So, hyperthreading is not
> a realtime anyway.
It could if the kernel had a concept of core speed and prioritized them ;-)
My solution for now, turn hyperthreading off in the BIOS.   Plain in simple !
> http://community.qnx.com/sf/go/post68503
