Forum Topic - How to check if a thread is alive: (3 Items)
I have a process that starts a thread. The thread runs continuously and updates a status variable. My main process does
several things and checks the status variable set by the thread.  I want to verify the thread is alive before I check
the status variable. I am not finding the mechanism to check if the thread is running. Can someone point me in the right
 direction?
Re: How to check if a thread is alive
	ret = pthread_kill(tid, 0);
will return EOK if the thread exists and ESRCH if it doesn't.
does several things and checks the status variable set by the thread.  I want to verify the thread is alive before I
check the status variable. I am not finding the mechanism to check if the thread is running. Can someone point me in the
 right direction?
> http://community.qnx.com/sf/go/post67187
I looked at that several times. Thought it would kill the thread. Didn't read enough to see that 0 does nothing. I'll
try it out, thanks
