Forum Topic - 3 questions, 1 about timers, 1 about multi-core and one about timer_timeout: (9 Items)
Hi all,
I have 3 specific questions and I hope I ask them in the proper forum.
1) Is the Intel HPET supported in QNX ? Or will it be?
2) Why do you need to specify a timeout in nanoseconds in TimerTimeout when the timeout occurs on a 'tick'?
3) When working with multi-core, you can use ThreadCtl(_NTO_TCTL_RUNMASK) to set the runmask for a certain thread. You
can do this at the begin of a thread. This might look inefficient. Another way to prevent this is the solution given in
http://qssl.com/developers/docs/6.3.0SP3/multicore_en/user_guide/how_to.html?printable=1#IMPACT . Wouldn't it be nicer
to do this somewhere in the pthread_attr_t? This might make your code more readable. What if you want to assign specific
 threads to specific CPU's, and I don't want to use the ThreadCtl(_NTO_TCTL_RUNMASK) approach at the beginning of the
thread, how do I use the  inherit mask then. Do I need to change it after each thread creation?
Freddy
Re: 3 questions, 1 about timers, 1 about multi-core and one about tim er_timeout
Hi Freddy,
Freddy Martens wrote:
> Hi all,
Not at this time.  We don't have any plans yet to support it.
Because the system time is kept in nanoseconds - it just so happens that
it goes up in increments in SYSPAGE_ENTRY(qtime)->nsec_incr per tick.
If you changed the tick time then something based on 'ticks' would
become invalid.
> You can do this at the begin of a thread. This might look inefficient.
> . Wouldn't it be nicer to do this somewhere in the pthread_attr_t?
> specific threads to specific CPU's, and I don't want to use the
> ThreadCtl(_NTO_TCTL_RUNMASK) approach at the beginning of the thread,
> thread creation?
In 6.3.2 you can set an inheritance mask such that any threads created
inherit the runmask of their parent.
Colin
> Regards,
> Freddy
> http://community.qnx.com/sf/go/post3104
cburgess@qnx.com
There's nothing in the operating system proper that needs to change for
this BTW, it's purely a board support package issue.
Hi Colin and Brian,
Thanks for your answers, but I want to confirm 2 things:
1) HPET, I still can write an application for X86 enabling the HPET right? This does not have to be in the x86 BSP right
3) The inherit mask, are you referring to the example given in the URL I mentioned ?
Freddy Martens
> right? This does not have to be in the x86 BSP right?
I didn't take a close enough read of the spec to see exactly how the
interrupts were being delivered to the CPU to say for sure. If interrupts
are being directed through the old, legacy style 8259 interrupt structure
than no, you don't need to do anything - just InterruptAttach[Event]()
to the proper number and off you go.
If you need to use the new APIC style of interrupts (or something else),
then you need to add some more interrupt callout routines to the startup
code (switching startup-bios to use APIC interrupts is one of those things
that we'd like to do, but there just never seems to be time to get around
to it).
> mentioned ?
Yup.
Brian,
I can implement it in the startup but I could also write a separate application that routes the interrupt to a free
interrupt (IRQ7) and then use the HPET as a fast timer right ?
I would be more comfortable by doing this in a separate application using a different IRQ when using it as a high speed
timer only.
Freddy
> application that routes the interrupt to a free interrupt (IRQ7) and
If I'm reading the spec right, you need to implement the IOAPIC interrupt
callouts in startup to use it.
> to it).
Since 2007 was there any progress made in that regard.
> > to it).
Enough that we've just discovered a problem with the interrupt initialization
code in the kernel that would prevent the io-apic callouts from working
unless some trickery is done. I don't know if the actual callouts will be
in the next release, but the kernel fix certainly will be.
	Brian
