Forum Topic - M2 build and 6.3.0 SP3: (6 Items)
Hello
Is it possible to run M2 build over 6.3.0 SP3 or I must have 6.3.2A installed?
I tried to unpack it on 6.3.0 SP3, rebuilt the boot image with procnto-smp but it does not live long. In few minutes
after boot system crashes with message:
Crash[0, 0] at ker_timer line 359.
I run it on single-core CPU (some Celeron as far as I remember).
Re: M2 build and 6.3.0 SP3
Well, maybe it does not crash while it's idle. I'm able to work in shell for quite a long time already. But it crashes
very soon if I start my applications which create some fuss for kernel.
RE: M2 build and 6.3.0 SP3
Hi Oleh,
If you didn't start from here
http://www.qnx.com/download/feature.html?programid=16784, which is the
baseline Momentics 6.3.2 release, then you're running odd/untested versions.
Speaking from a support perspective, if you want to build the kernel and run
it, then you need to get the above release. We'll guarantee backwards
compatibility (6.3.0SP3 built binaries should run fine on 6.3.2), but we do
not guarantee forward compatilibity (6.3.2 on 6.3.0SP3 is an untested
configuration, and therefore unsupported.).
This is layed out in the Building the OS Source documentation.
Pre-requisites
To build the Neutrino OS source you need to have:
   1. Momentics Development Environment (6.3.2) installed for the build
tools.
      NOTE: This must be the latest 6.3.2 complete development environment
from this download site.
      A 6.3.2 or 6.3.0 development environment installed prior to 12/09/2007
will not work properly and will result in build errors/problems.
      To build the latest you need the latest released developer
environment.
Cheers,
-Brian
Sent: Tuesday, November 27, 2007 14 50
To: ostech-core_os
Subject: Re: M2 build and 6.3.0 SP3
quite a long time already. But it crashes very soon if I start my
OSTech
http://community.qnx.com/sf/go/post2992
Re: RE: M2 build and 6.3.0 SP3
Well, we tried 6.3.2 right after it was released in May-June 2006. But we had problems with it. The kernel crashed from
time to time in customer installation and we had to rollback to 6.3.0. That's why we do not use 6.3.2 yet and I can
assume current crashes I experience with M2 could be the same problem we had previous Summer.
I tried to boot the system several more times. I was even able to roughly locate which of my applications causes kernel
to crash soon after it's started. However the application is quite large and multithreaded so I do not have even the
slightest idea what could trigger the fault.
All the times it crashed in ker_timer 359 except for one time in nano_sched 1333.
RE: RE: M2 build and 6.3.0 SP3
Hi Oleh,
The 6.3.2 released in May/June 2006 isn't the same 6.3.2 which was released
in September 2007. The former was a kernel update and the latter is a
baseline release, and is the only supported platform for building the M2
build.
Once you upgrade to Sept 2007 6.3.2, if you're seeing crashes, you can
either seek help here or submit a support ticket if you have a plan.
With regards to the causes of kernel crashes, there is a list at the
following URL:
http://community.qnx.com/sf/wiki/do/viewPage/projects.core_os/wiki/Kernel_Cr
ashed_Common_Causes
We also have a primer on debugging kernel crashes in our technotes, which
you can find here:
http://www.qnx.com/developers/docs/6.3.2/neutrino/technotes/proc_dump.html
Cheers,
-Brian
Sent: Tuesday, November 27, 2007 15 52
To: ostech-core_os
Subject: Re: RE: M2 build and 6.3.0 SP3
had problems with it. The kernel crashed from time to time in customer
yet and I can assume current crashes I experience with M2 could be the same
locate which of my applications causes kernel to crash soon after it's
not have even the slightest idea what could trigger the fault.
1333.
OSTech
http://community.qnx.com/sf/go/post2994
Re: RE: RE: M2 build and 6.3.0 SP3
Hi Brian
> build.
I did not build it myself. I downloaded binaries from your site.
However it does not matter if it is extracted over 6.3.0SP3 or 6.3.2. Today I've unpacked it over 6.3.2 installation
downloaded from the link you provided and it crashes as well.
By the way, the image with Memory Partition libraries does not boot at all. I have to build it without [+keeplinked
module=apm module=partmgr]. You can find my boot image build script in attachment.
No, I do not currently have a support plan. And as far as I understood from conversation with your developers last year
you did not have any means for tracking down crashes like this remotely. :(
Well, maybe I could send you some of my applications if you would agree to run them in your test machine. However with
just few processes running it could not always be easy to reproduce. You may have to restart it several times.
> following URL:
> ashed_Common_Causes
Those all are unlikely. It is a user-mode application and most of those causes are hardware access or driver related.
Memory usage at the time of crash is around 60%.
> you can find here:
Well, most of the times it only displays Crash[0, 0] at ker_timer 359 or nano_sched 1333. Sometimes it does not display
any message at all. I could see a dump like in that example only once. The "screenshot" ;) for it is in attachment as
well.
Attachment: Compressed file files.zip 77.07 KB
