Forum Topic - InterruptLock(): (8 Items)
InterruptLock()
I'm not sure if this is the right place to ask, but still would appreciate if somebody could feed my inquisitive mind
(Without getting into the debate of "Why would you want to do this..." et al) :-)
Can I call InterruptLock() recursively? Something like this:
InterruptLock(lock1);
/* do something */
InterruptUnlock(lock1);
Will lthe interrupts be enabled after first or second call to InterruptLock()?
And how about this:
InterruptLock(lock2);
/* do something */
InterruptUnlock(lock2);
Dan
Re: InterruptLock()
> /* do something */
Nope, InterruptLock() doesn't count (neither does InterruptDisable()). As
as matter of fact, you'll permanently hang up on the spin lock of the
second InterruptLock.
> And how about this:
> /* do something */
You won't hang on this one, but interrupts will be re-enabled after
the first InterruptUnlock().
Re: InterruptLock()
You can use InterruptStatus() to check to see if interrupts are
currently disabled.
> > /* do something */
> > And how about this:
> > /* do something */
> http://community.qnx.com/sf/go/post2846
cburgess@qnx.com
Re: InterruptLock()
> currently disabled.
But that won't help in the second case, with two different lock variables.
On an SMP system, you could let multiple people into the critical region
if you try something like:
	if(InterruptStatus() == 0) {
Re: InterruptLock()
True, but you could change the second InterruptLock to merely a
spinlock, couldn't you?
eg
status = InterruptStatus();
if ( status ) {
    InterruptLock(&lock2);
} else {
    SPINLOCK(&lock2);
> > currently disabled.
> variables.
> http://community.qnx.com/sf/go/post2853
cburgess@qnx.com
Re: InterruptLock()
> eg
> if ( status ) {
> } else {
>     SPINLOCK(&lock2);
Yup, and the InterruptUnlock to a SPINUNLOCK in that case.
Re: InterruptLock()
So what is the correct way (in a driver) to obtain two locks on an SMP machine? I don't find "SPINLOCK" macro / function
 anywhere!
[daniel@localhost qnx632]$ grep -Rn SPINLOCK /opt/qnx632/target/
[daniel@localhost qnx632]$ grep -Rn SPINLOCK /opt/qnx632/host/
Re: InterruptLock()
> machine? I don't find "SPINLOCK" macro / function anywhere!
Left as an exercise for the user :-).
It's just the tail end of the InterruptLock inline - the part after
interrupts have been disabled. Ditto with SPINUNLOCK - it's the part in
InterruptUnlock before enabling interrupts.
