Forum Topic - shm_open & mmap: (5 Items)
shm_open & mmap
Hi everyone.
I am a newbie in C programming and QNX. I am currently working on a project based on C programming in QNX and have met
cross some problems.
There are some existing executable programs compiled in QNX 6.3.2. Now the OS has been updated to QNX 6.4.0, and a few
of the executable programs cannot run correctly. I checked the source code and found the problems probably occured when
shm_open or mmap was called. The interesting thing is that shm_open is also called in other executable programs and they
 can work successfully.
In the problem program, shm_open is called like:
" shm_descr = shm_open(CMD_INTERFACE_SHM_NAME,O_RDWR, S_IRWXU); "
And in the normal program, it's called like:
" fd = shm_open(devName,O_RDWR|O_CREAT,0); "
Does the flag's difference matter? Or the problem was caused by the update of QNX OS?
RE: shm_open & mmap
Check the value of errno after shm_open fail, it should give you good idea of that is going on.
-----Message d'origine-----
De : Yuan Sun [mailto:community-noreply@qnx.com]
Envoyé : 19 juillet 2010 13:29
À : ostech-core_os
Objet : shm_open & mmap
Hi everyone.
OSTech
http://community.qnx.com/sf/go/post59844
Re: shm_open & mmap
In the first example, it fails because the file doesn't already exist (you can not logically open a file for read and
write if it is not already created).
In the second example it succeeds because you instruct it to create the file first if it doesn't already exist.
If you check the value of errno after the first exmaple fails it will indicate that the "file is not found" meaning you
need to O_CREAT it first.
Good luck!
Re: shm_open & mmap
yes, the differences do matter - but not only those in the flags.
Even if you first do
and call
after that (i.e., when the shared memory object already exists), it'll still fail.That is because your object's file
permissions (the third argument) are set to 0 when it is created. That means no-one will be granted read or write access
(BTW: I'm always assuming that  devName  and  CMD_INTERFACE_SHM_NAME  are identical... if they aren't, there's another
problem...)
Try changing the calls like this:
   fd = shm_open( devName, O_RDWR|O_CREAT, S_IRWXU );
   shm_descr = shm_open( CMD_INTERFACE_SHM_NAME, O_RDWR, 0 );
- Thomas
Re: shm_open & mmap
Hi guys,
Thank you so much for the help. I think I have missed some information.
The devName and CMU_INTERFACE_SHM_NAME are not the same. They are in two different files, and defined respectively as
follows.
#define devName "/apc8620RM"
#define CMD_INTERFACE_SHM_NAME "/cmdinterface.shm"
And I have another simple question. How can I check the errno value?
