Forum Topic - syslog problem: (3 Items)
syslog problem
Hello
Test code:
int main(int argc, char **argv, char **envp)
        openlog("zzz", LOG_PID | LOG_NDELAY, LOG_DAEMON);
        syslog(LOG_NOTICE, "zzz1");
        close(3); // close /dev/log fd
        syslog(LOG_NOTICE, "zzz2");
        return (EXIT_SUCCESS);
Actual results:
Jul 16 11:03:01 nto zzz[607952922-1]: zzz1
Expected results:
Jul 16 11:03:01 nto zzz[607952922-1]: zzz2
is it bug or feature?
Re: syslog problem
Instead of using close(3), can you try using closelog();
This should resolve the issue and get the expected results.
Andy
> Hello
> Test code:
> Actual results:
> Expected results:
Re: syslog problem
I did so already, but it's only example. In a real program is closing all descriptors after fork() and as a result I'm
getting this problem, it's work on many unix, bun not in QNX.
