Forum Topic - POSIX incompatibility of constants from <float.h>: (3 Items)
While trying to compile this code:
#include <float.h>
const double test = DBL_MAX;
with qcc I get the following error:
float_test.c:3: error: initializer element is not constant
cc: /opt/qnx641/host/linux/x86/usr/lib/gcc/i386-pc-nto-qnx6.4.0/4.3.3/cc1 error 1
while according to standards (SUS: http://www.opengroup.org/onlinepubs/9699919799/basedefs/float.h.html, how about POSIX
?) this "shall be defined as constant expressions". Compiling this code with QCC works as expected.
Re: POSIX incompatibility of constants from <float.h>
> #include <float.h>
POSIX?) this "shall be defined as constant expressions". Compiling this code with QCC works as expected.
gcc/qcc defaults to C90 + GNU extensions. DBL_MAX and others were not
required to be a constant expression in C90.
"FLT_RADIX shall be a constant expression suitable for use in #if
preprocessing directives; all other values need not be constant
expressions."
The requirement in C99 was added so the float values could be used as
initializers.  Our headers are conditioned based on __STDC_VERSION__ and
so if you compile with -Wc,-std=c99 DBL_MAX will be defined as a
constant expression. e.g. on x86 DBL_MAX will be 0xf.ffffffffffff8p+1020.
Ryan Mansfield
> expressions."
Interesting, what could be the benefit for such a constant of not being a constant expession? Was anybody going to take
an address of DBL_MAX? :) Or was it better for quality of code being compiled? :)
