Forum Topic - Crash before boot script: (3 Items)
I'm working on a MIPS r4k based BSP and I believe I'm close to getting the kernel up and running but it's still crashing
 before it executes the boot script.  I've set breakpoints on nano_clock and verified that the clock is working.
It seems to be crashing at imagefs_mount_mounter() in the bootimage_init() function.  Any ideas on what to look for?
Also, in the BSP, does "startup_memory_map" in lib/mips/map_startup.c require a "tlb_bypass" function in cases where the
 address to be mapped is in kseg1 (unmapped and uncached area)?  This is what I did to get around problems with
accessing the serial debug port.
Re: Crash before boot script
Actually the crash is not before the boot script.  The "Welcome to QNX" banner is printed from the boot script but the
first app that is executed causes a crash (first app was serial driver originally but tried other apps including a
simple hello world).  Shutdown memory dump info is printed on the debug screen (log attached).
Setting a break before "shutdown" function shows it was called from "usr_fault".
Any suggestions on where to look for the cause of the crash?
Attachment: Text qnx_crash.log 1.4 KB
You would probably benefit from using the kernel debugger.
At least generate a procnto-32_g.sym (add [+keeplinked] to the procnto
line in your buildfile), then you can examine the instruction
at 0x80172ff0
> QNX" banner is printed from the boot script but the first app that is
> tried other apps including a simple hello world).  Shutdown memory
> "usr_fault".
> http://community.qnx.com/sf/go/post2048
cburgess@qnx.com
