Forum Topic - mmap with PROT_WRITE appears to force an unnecessary flush to disk even if msync isn’t called: (2 Items)
I’m posting this here (instead of the filesystem forum) since it happens on more than one filesystem type (which leads
me to believe it’s a bug with mmap, not with the filesystems).
In my application, I open a file as read/write, mmap it in, compare it with new data, and only if the new data is
different do I copy the changed data into the mmap’d buffer and call msync. The goal is to avoid unnecessary writes to
our NOR flash filesystem.
However, on both our devf-generic NOR flash FFS3 and devb-eide compact flash IDE QNX4 filesystems, it appears that
simply mmap’ing the file with PROT_WRITE is enough to force some kind of a flush out to the physical storage on munmap
(even if msync was never called because the data didn’t change). If all I do is mmap with PROT_WRITE and munmap, the
flash filesystem ends up reclaiming blocks (and periodically getting delayed for a couple seconds because of this).
The workaround is pretty straightforward: If I do my initial mmap with PROT_READ only, compare my contents, and then do
an mprotect with PROT_WRITE only if the contents have changed, the unnecessary filesystem flushes don’t occur.
Interestingly, if I do my initial mmap with PROT_READ only, then do an mprotect with PROT_READ | PROT_WRITE, and then
munmap (no msync), the filesystem data doesn’t appear to be flushed. Only if the initial mmap has the PROT_WRITE flag
is the physical storage unnecessarily touched.
I’m attaching a sample program that runs through several different sets of mmap and mprotect flags (runs forever with
100 runs in each set). You need to pass in a filename that it will write to, and optionally the string values that it
will write. Here is the example output from our NOR flash filesystem (as previously mentioned, I was able to reproduce
the relative differences on a compact flash IDE filesystem as well, though the absolute delays are much shorter):
# /tmp/z_test_mmap /persist/test_file.txt
Toggling between writing hello and hello to /persist/test_file.txt
Elapsed time 11339 msec for 100 cycles of mmap PROT_READ | PROT_WRITE, no additional mprotect
Elapsed time    63 msec for 100 cycles of mmap PROT_READ, mprotect PROT_READ | PROT_WRITE
Elapsed time    62 msec for 100 cycles of mmap PROT_READ, no additional mprotect (file is not actually updated even on a
 change)
Elapsed time 11495 msec for 100 cycles of mmap PROT_READ | PROT_WRITE, mprotect PROT_READ (file is not actually updated
even on a change)
Elapsed time    66 msec for 100 cycles of mmap PROT_READ, mprotect PROT_READ | PROT_WRITE, but no mysnc (file is not
actually updated even on a change)
# /tmp/z_test_mmap /persist/test_file.txt hello world
Toggling between writing hello and world to /persist/test_file.txt
Elapsed time 11594 msec for 100 cycles of mmap PROT_READ | PROT_WRITE, no additional mprotect
Elapsed time 11438 msec for 100 cycles of mmap PROT_READ, mprotect PROT_READ | PROT_WRITE
Elapsed time    78 msec for 100 cycles of mmap PROT_READ, no additional mprotect (file is not actually updated even on a
 change)
Elapsed time 13454 msec for 100 cycles of mmap PROT_READ | PROT_WRITE, mprotect PROT_READ (file is not actually updated
even on a change)
Elapsed time    33 msec for 100 cycles of mmap PROT_READ, mprotect PROT_READ | PROT_WRITE, but no mysnc (file is not
Attachment: Text z_test_mmap.c 4.79 KB
Re: mmap with PROT_WRITE appears to force an unnecessary flush to disk even if msync isn’t called
I've provided the same information to your support case and our bug tracking system.  This is a bug in the memmgr for
sure.  The crux is that code in the OS (memory_reference() ) can turn on both NEEDSSYNC and MODIFIED to the mapping even
 if the underlying file backing mapping hasn't been modified itself.  The logic is simply to check if PROT_WRITE is on,
and then turn on MR_WRITE.  The behaviour is likely not intended as doing you've shown that PROT_READ mapping avoids
this and you can then do an mprotect() to turn on the PROT_WRITE post mapping (and still not get flushed).
While I'm not completely familiar with _why_ the unconditional PROT_WRITE=MR_WRITE logic exists (I'm sure there is a
wierd corner case), I've provided a patch that undoes any pending 'NEEDSSYNC" after setup since there isn't a way for
the user to have modified the mapping before we've returned from mmap().
You can use the patch if you're blocked while the OS team reviews the issue.
Thanks!
-Adam
Here is a patch against 6.4.1:
Index: memmgr/vmm_mmap.c
--- memmgr/vmm_mmap.c   (revision 274448)
+++ memmgr/vmm_mmap.c   (working copy)
@@ -380,6 +380,18 @@
                        if(mm->end >= end_vaddr) break;
                        mm = mm->next;
+               /* ADAM */
+                       /* Memory reference might have set the NEEDSSYNC even
though it really shouldn't since
+                               we haven't returned control to the user and we
don't modify the underlying object
+                               at any point on their behalf.  The last end of
the mappings (zero fill) could be
+                               due to the OS but it's neither part of the file
nor should it result in a sync.
+                       if(mm->obj_ref && mm->obj_ref->obp &&
mm->obj_ref->obp->hdr.type == OBJECT_MEM_FD) {
+                       obp->mem.mm.flags &= ~MM_FDMEM_NEEDSSYNC;
        return r;
