Forum Topic - Install QNX 6.4.1 via SATA DVD drive?: (1 Item)
Hi-
Not sure this goes here, let me know if not.
I'm having a hard time installing QNX (6.4.1) on a PC/104+ system that I'm putting together, and I suspect that maybe it
 is because I'm using a SATA DVD drive to install.  I'm using the following board:
http://www.fastwel.com/products/356046/pc104/cpumodules/327125.html
Which is an x86 based PC/104+.  I'm using an HP 1260i DVD drive plugged into the SATA port on the board.  The board
picks up the drive and goes to boot up and then it sits forever on a black screen with one line:
BOOTING QNX SDP D
Thought maybe you guys might have some ideas...  I tried 6.3.2 and had a similar problem.
Thanks!
