Forum Topic - wordexp: (3 Items)
wordexp
Why is this function in the library and in the documentation if it's not supported?  The documentation says it's not
supported, but when porting code to Neutrino, you wouldn't expect an unsupported function to compile.  Also, the
documentation says it should set errno, but it doesn't, it only returns -1.
Is there an alternative function I can use to do word expansions?
Re: wordexp
My guess is: To be at least partially POSIX-compliant...
One might argue that a minimal implementation stating that it won't do anything is still a 'valid' implementation --
although from a practical point of view, I'd readily agree with you.
You're right about the docs: Not  errno  is set, but the error code is returned (the -1 you're seeing is ,in fact'
WRDE_NOSYS).
- Thomas
RE: wordexp
I'll create a PR to update the docs for wordexp().
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
> From: Thomas Haupt [mailto:community-noreply@qnx.com]
> Sent: Thursday, January 07, 2010 4:34 PM
> To: ostech-core_os
> Subject: Re: wordexp
> error code is returned (the -1 you're seeing is ,in fact' WRDE_NOSYS).
> - Thomas
> http://community.qnx.com/sf/go/post44771
