Forum Topic - Performance versus compiler version: (8 Items)
As anyone done a comparison of kernel's performance when compile with Watcom/2.95.3/3.3.5/4.2.1 ?
RE: Performance versus compiler version
> From: Mario Charest [mailto:mcharest@zinformatic.com]
> Sent: September 21, 2007 11:55 AM
> To: ostech-core_os
> Subject: Performance versus compiler version
We have some numbers internally.  I can see what we can do
about getting them up on the Wiki.  It is more a matter of
format conversion than anything else.
Short story seems to be:
* Watcom rules size/speed/codegen for x86 over 2.*, 3.* series
* Starting with GCC 4.* we'll likely switch production builds
Thomas
Re: Performance versus compiler version
I actually did a rather large and comprehensive comparison a few months ago, including the difference between
optimization levels.
If it's ok to post the full results here, then I will.  I'm the only one with the original spreadsheet, because I posted
 it as HTML before.  I can tweak as necessary.
For x86, the watcom compiler performs much better for size and speed than 2.x or 3.x with any optimization level.  4.x
consistently outperforms 2.x and 3.x for speed by 2 or 3 percent.  With the -Os option, it actually produces smaller
code than the watcom compiler.
There was negligible difference between 2.x and 3.x for all architectures, but 4.x consistency outperformed - usually 1
to 3 percent speed wise, and 8 percent or so for size. (-O2 and -Os only)
Interestingly, -O2 flag often had better speed performance than -O3 using gcc 4.2.  The theory is that using -O3
generates huge binaries, and the pipeline suffers.
We'll see what we can do about posting the big chart of the results if people are interested.
I think it would make a good wiki page. So...
I've created a small section for "performace measurements and benchmarks" on the tech page and created this page for
compiler measurments:
http://community.qnx.com/sf/wiki/do/viewPage/projects.core_os/wiki/Compiler_performance_measurements?_message=
1190397861940
If you want to upload your spreadsheet, I suggest putting it in the documents section and then link it from the above
wikipage.
-ad
Wow...4 usec message pass with a fair amount of data...that's pretty cool.
Kevin
> or 3.x with any optimization level.  4.x consistently outperforms 2.x and 3.x
> smaller code than the watcom compiler.
>  4.x consistency outperformed - usually 1 to 3 percent speed wise, and 8
> 4.2.  The theory is that using -O3 generates huge binaries, and the pipeline
> suffers.
And how about the intel compiler?
I haven't actually tried it with the Intel compiler yet.  Since it's just for x86, more tests wouldn't take long.
If someone lets me know where to get it, I can see what can be done.
Any progress?
