Forum Topic - _NTO_CHF_DISCONNECT pulse: (3 Items)
In manual for ChannelCreate
_NTO_CHF_DISCONNECT
Pulse code:
_PULSE_CODE_DISCONNECT
Pulse value:
None
Deliver a pulse when all connections from a process are detached (e.g. close(), ConnectDetach(), name_close()). If a
process dies without detaching all its connections, the kernel detaches them from it. When this flag is set, the server
must call ConnectDetach( scoid ) where scoid is the server connection ID in the pulse message. Failure to do so leaves
an invalid server connection ID that can't be reused. Over time, the server may run out of available IDs. If this flag
isn't set, the kernel removes the server connection ID automatically, making it available for reuse.
What a "ConnectDetach( scoid ) where scoid is the server connection ID in the pulse message" is meant here if pulse
value is mentioned as "None"?
Also the text tells about "all connections from a process are detached". Is there a single server connection id for
multiple client connection ids indeed?
Re: _NTO_CHF_DISCONNECT pulse
Ah sorry! Now I see it. There is scoid in pulse structure.
OK, another question on topic...
What if _PULSE_CODE_DISCONNECT will be queued to channel right before server is going to call ChannelDestroy()? The
pulse memory will be deallocated by kernel, of course but what about scoid? Will it still be lost?
