Forum Topic - telnet session shall inherit environment of main session: (4 Items)
I set some enviroment variables in my boot script, which in the end opens a ksh. The environment variables I set appear
to be part of the environment of this shell.
When I telnet to this system though, how can I make sure it also has the same environment? It must take its environment
from somewhere (e.g. 'set' prints out a lot). How to let a telnet session inherit the environment variables of the
session I have on the serial terminal?
Note I'm on an embedded target so there's no .profile, etc. just inetd/telnetd, terminfo etc.
- Malte
Re: telnet session shall inherit environment of main session
as initd and telnetd both are using fork()/exec()
I would expect that your shell gets the env you have set before starting intd.
Did you set your env before starting initd/telnetd?
Yes I did, but it still does not inherit my environent. However it seems that telnetd is trying to create a certain
'well defined and secure' environment so it removes everything except a few certain standard environment variables.
The only solution I found is to explicitly create the desired environment using an /etc/profile script.
Looking into services/telnetd/sys_term.c, it appears that the slave end of telnetd will call a function named
'scrub_env()' which will erase the environment except for the following variables:
   XAUTH, XAUTHORITY, DISPLAY, TERM, EDITOR, PAGER, LOGNAME,
   POSIXLY_CORRECT, TERMCAP, PRINTER
So you should be able to inherit (from inetd's environment) e.g. the terminal type (TERM), but not e.g. the home
directory (HOME).
- Thomas
