Forum Topic - Test to determine if in interrupt context?: (2 Items)
How can I check whether or not I'm currently executing in an ISR or a thread?
I'm running Momentics 6.3.2.  I'm looking for something similar to VxWorks  intContext() call.
Thanks!
Rob
AW: Test to determine if in interrupt context?
maybe it is best to start with the interrupt section in the programmers manual.
you find the 6.3.2 version here
http://www.qnx.com/developers/docs/6.3.2/neutrino/prog/inthandler.html
you will see that things are different, and you do not need an intContext() at all.
-----Ursprüngliche Nachricht-----
Von:	Rob Maher [mailto:community-noreply@qnx.com]
Gesendet:	Do 08.10.2009 17:38
An:	ostech-core_os
Cc:
Betreff:	Test to determine if in interrupt context?
Thanks!
Rob
OSTech
http://community.qnx.com/sf/go/post39610
Attachment: Text winmail.dat 3.53 KB
