Forum Topic - sem_open() and path issues: (6 Items)
Hello all,
I've got a small problem with sem_open(). From the reference (at: http://www.qnx.com/developers/docs/6.4.1/neutrino/
lib_ref/s/sem_open.html ) the following code:
int main(int argc, char** argv)
	sem_t* sem_ = sem_open("/var/wf/mysem", O_CREAT | O_EXCL, 0777, 0);
should create a semaphore at /var/wf/mysem.
Instead of getting that, i get a semaphore created in /dev/sem called var/wf/mysem
Note that with mq_open() and shm_open() I get the expected behaviour. Just not with sem_open().
Any ideas?
It's a bit annoying because I want all my process to create their resources in a specific folder, so that if anything
goes wrong (which means my own resource manager dies), i can just delete all of them with rm and implement a simple
cleanup procedure.
Re: sem_open() and path issues
Also, is there any way to create a binary semaphore, i.e. not a counting one but limited to 1? Do I have to use a mutex
to do that?
The docs didn't track the 6.3 change of moving named semaphores directly into the kernel, namely that they now operate
in a flat namespace under /dev/sem.
This was done to simplify and conserve kernel resources (previously each object was an attached name/mountpt).
This is completely allowed by POSIX (names do not have to appear in the pathspace and the definition of any non-leading
'/' is implementation-defined).
>  with sem_open().
Actually, mq+libmq operate a similar flat namespace under /dev/mq for the same reasons (mqueue+libc left as-is).
>  a specific folder, so that if anything goes wrong (which means my own
> simple cleanup procedure.
You can still incorporate a unique component into each semaphore name, and then do a wildcard deletion (ie "rm -rf /var/
sem/MYID1/" could be "rm -f /dev/sem/*MYID1*").
RE: sem_open() and path issues
I created a PR to get the docs updated.
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
> From: John Garvey [mailto:community-noreply@qnx.com]
> Sent: Tuesday, October 06, 2009 1:02 PM
> To: ostech-core_os
> Subject: Re: sem_open() and path issues
> operate in a flat namespace under /dev/sem.
> behaviour. Just not
> >  with sem_open().
> their resources in
> means my own
> rm and implement a
> /var/sem/MYID1/" could be "rm -f /dev/sem/*MYID1*").
> http://community.qnx.com/sf/go/post39440
> then do a wildcard deletion (ie "rm -rf /var/sem/MYID1/" could be "rm -f /dev/
> sem/*MYID1*").
I guess that could be a good solution to that problem. Thanks for pointing that out :)
I still have one open issue with semaphores, and that is how to have counting semaphores counting up to a specified
amount (e.g. binary semaphores) and not up to the SEM_VALUE_MAX constant. I'm either blind or there's nothing in the
docs that suggests it being possible (unless by first checking the value of the semaphore and then deciding or not to do
 the sem_post() depending on its value).
Did I miss something?
POSIX decrees that its semphares are always counting. To get binary
behaviour, you need to use a mutex.
