donghwan kim(deleted)
installation fail SDP7.1 QNX Software Center
09/25/2020 3:24 AM
post120951
Hi, I'm trying to install QNX Software Center in my linux server machine with SDP7.1 License.
So, I download "QNX Software Center 1.6.2 Build 202009011705 - Linux Hosts" file at below link
http://www.qnx.com/download/feature.html?programid=53630
and send it to my linux server, and give it running permission with 'chmod +x '.
after that, press 'q' and 'y' for accept license agreements, and install at default path.
Please type y to accept, n otherwise: y
Current directory: /home/vcuentry
Specify installation path (default: /root/qnx):
but install was fail with below error message
Installing QNX Software Center into /root/qnx/qnxsoftwarecenter
User configuration is stored in /root/.qnx
Launching QNX Software Center using /root/qnx/qnxsoftwarecenter/qnxsoftwarecenter
Signal caught, cleaning up
root@{Server name} - {My PC name} :/home/{My user name}# Qnxsoftwarecenter:
An error has occurred. See the log file
/root/.qnx/swupdate/.metadata/.log.
so i looked up /.metadata/.log.
there were more logs than below. but I think this logs are contains error message.(These logs are at the beginning.)
root@{My PC name} :/home/{My user name}# cat /root/.qnx/swupdate/.metadata/.log
!SESSION 2020-09-24 08:08:44.911 -----------------------------------------------
eclipse.buildId=1.6.2
java.version=1.8.0_265
java.vendor=AdoptOpenJDK
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -perspective com.qnx.swupdate.app.perspective.startup
Command-line arguments: -os linux -ws gtk -arch x86_64 -perspective com.qnx.swupdate.app.perspective.startup
!ENTRY org.apache.felix.scr 4 0 2020-09-24 08:08:45.223
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.apache.felix.scr [2]
Unresolved requirement: Import-Package: org.apache.felix.service.command; version="[1.0.0,2.0.0)"; resolution:="
optional"
Unresolved requirement: Import-Package: org.osgi.service.cm; version="[1.6.0,2.0.0)"; resolution:="optional"
Unresolved requirement: Import-Package: org.osgi.service.component; version="[1.4.0,1.5.0)"
at org.eclipse.osgi.container.Module.start(Module.java:457)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$1.run(ModuleContainer.java:1820)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$2$1.execute(EquinoxContainerAdaptor.java:150)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1813)
would you help me with resolve of this phenomenon?
