Sada Murugan
10/16/2007 2:37 PM
post2035
I've been able to debug the kernel over a physical serial port, but I had to do some things a little different than the
wiki page says.
In the suggested boot section of the build file, on the wiki we have:
[virtual=x86,bios +compress] boot = {
# Reserve 64k of video memory to handle multiple video cards
startup-bios -s64k -Dconsole -K3f8..9600
gdb_kdebug
# PATH is the *safe* path for executables (confstr(_CS_PATH...))
# LD_LIBRARY_PATH is the *safe* path for libraries (confstr(_CS_LIBPATH))
# i.e. This is the path searched for libs in setuid/setgid executables.
[+keeplinked]
PATH=/proc/boot:/bin:/usr/bin:/opt/bin LD_LIBRARY_PATH=/proc/boot:/lib:/usr/lib:/lib/dll:/opt/lib procnto-instr -P
I've only got it to work with:
# for second serial port
startup-bios -s64k -Dconsole -K 8250.3f8.9600
# for first serial port
startup-bios -s64k -Dconsole -K 8250.2f8.9600
Maybe that's hardware dependent, so is intentionally left out of the wiki.
My other major problem was that I needed the debug variant of procnto-instr, so I had to change the line to reflect that
PATH=/proc/boot:/bin:/usr/bin:/opt/bin LD_LIBRARY_PATH=/proc/boot:/lib:/usr/lib:/lib/dll:/opt/lib procnto-instr_g -P
This is actually not built by default, because there is a Makefile.dnm within services/system/proc/x86/o.instr.g, so
that has to be removed to build this variant. I probably could have used procnto_g, which does get built by default.
Anyway, without the debug variant built, I wasn't having much luck. I know that it should be completely obvious, but I
like to be able to cut and paste sections from guides and trust that they are correct, so I think the wiki should be
updated.
-SM
PS - I'll be posting a guide on kernel debugging with QEMU shortly. It will be under the same "QEMU and Neutrino" page
under debugging on the kernel wiki.
