Maurizio Rossi
Momentics 6.4.0 running natively on x86.
Maurizio Rossi
11/06/2008 9:24 AM
post16081
there are some glitches in Momentics 6.4.0 running natively on x86.
Secondary boot loader on qnx6 fs.
If the output of the secondary boot loader in on the bottom row of the screen only the first boot image can be seen.
You can select any available boot image but only the first one is visible.
Login window.
After system boot the login window reports an invalid uptime (se the attached image in logwin.png).
The reported value is correct after one hour of system uptime.
devb-umass and USB floppy drives.
Plugging in an USB floppy drive cause some strange things.
devb-umass started automatically does not handle the device (see usbplug.txt).
The utility usb -vv reports a valid USB floppy device connected to the USB interface.
At this point the system runs slower and one thread in the "mcd" daemon stays in the "READY" state.
Starting manually devb-umass cause the device to appear in "/dev" as "/dev/hd1".
At this point "mount -t dos /dev/hd1 /myfd" reports success (exit code 0) but "ls -la /myfd" reports "No such device or
address (/myfd)" (see usbfloppy.txt).
Maurizio Rossi
