Community
Tracker
Forum Topic - QNX6.4.0 M8 Build on Atom: (8 Items)
I'm testing 6.4.0 on a Kontron system based on Intel Atom processor.
This board has the following devices:
network adapter vid=0x8086 did=0x10d3
graphics adapter vid=0x8086 did=0x8108
I don't konw if what I'm reporting is a bug or not.
The "devnp-i82544.so" is unable to manage the network controllers i.e. refuse to startup.
The "devn-i82544.so" from QNX6.3.2 running on 6.4.0 works fine.
In both cases the vid/did parameters are passed to the driver.
Adding the "devg-poulsbo.so" driver to "/etc/system/enum/devices/graphics" cause the photon environment not to startup.
Maybe this driver does not work with Photon?
Maurizio Rossi
Re: QNX6.4.0 M8 Build on Atom
where did you get the devg-poulsbo from?
Just as an experiment,
restart your computer and after you select an image, hit the space bar for
extra boot options, hit F6 two or three times and hit enter.
Take note of the last message before booting halts.
Also, on another startup, enable a debug shell, and when boot halts and kicks
you to the shell, set your path and run "get_hw_info" and attach a copy of
the results here (you can use a usb key to get the results onto a comp. with
net access).
I'm looking forward to hearing the results of these.
Cheers,
-Aaron
> refuse to startup. The "devn-i82544.so" from QNX6.3.2 running on 6.4.0
> works fine.
> cause the photon environment not to startup. Maybe this driver does not
> work with Photon?
> Regards,
> Maurizio Rossi
> QNX Software Development Platform 6.4.0 Pre-Release
> http://community.qnx.com/sf/go/post14911
Attached to this message some more informations.
These informations are collected on a normal running system.
The "graphics" file contains changes added to "/etc/system/enum/devices/graphics".
After modifying "-d poulsbo" to "-d vga -d vesabios -d poulsbo" photon starts up but only in vesabios mode i.e. poulsbo
driver does not run.
The "graphlog.txt" is a system log capture of what happens when I try to change the graphic driver from vesabios to
pulsbo.
Maurizio Rossi
Attachment: Compressed file graphics.zip 7.97 KB
RE: QNX6.4.0 M8 Build on Atom
Hi Maurizio:
   One of the things that came up with the devnp version of the driver
is that we have some code in the devn driver which we don't know if we
can put in the public domain.  We ended up taking code from FreeBSD to
do the EEPROM reading so it's possible that the devn driver may support
more devices than the devnp (although I thought that we were the same).
Could you tell me what the output from sloginfo reports when using the
devnp driver?
	You'll also find that the devn driver (built for 6.4.0) is still
included in the packaging for exactly this reason, so you can given that
one a try as well.
		Robert.
From: Maurizio Rossi [mailto:community-noreply@qnx.com]
Sent: Monday, October 13, 2008 9:58 AM
To: sdp640prerelease-community
Subject: QNX6.4.0 M8 Build on Atom
refuse to startup.
startup.
Maurizio Rossi
Re: RE: QNX6.4.0 M8 Build on Atom
Attached to this reply the results of some tests.
Maurizio Rossi
Attachment: Text netlog.txt 3.09 KB
we ran into this recently, modify the enmerator file to force the poulsbo driver to start in 800x600 ... notice -g
option
device(pci, ven=8086, dev=8108)                         # SGX/Poulsbo
  start/wait( dispconf -i "0x$(ven),0x$(dev),$(index)" -d poulsbo -g "xres=800,yres=600" )
  requires/wait( $(IODISPLAY_CMD), )
  mount(-Tio-display "vid=0x$(ven),did=0x$(dev),deviceindex=$(index)" )
the driver is reporting it supports all generic modes, and maybe it should, but currently all modes do not work, only
800x600, 1024x768, and 1280x1024
I am having the same problem. Unable to boot into photon. I tried forcing the resolution to 800*600 but of no use.
Please help me boot QNX6.4 on a ATOM platform with poulsbo driver.
Thanks and Regards,
Nagaraj.
