artf2345
The application builder applications called from the command line cause the following error under 641M5: Ap: Unable to open resource file (/net/host_name.domain_name/) The same code works fine under 641M4 best regards
Can you provide more details: - Procedure how to repeat - Sample application - Does the problem happen in M6? M5 is now out of date. Thanks, Max -----Original Message----- From: Piotr Trojanek [mailto:community-noreply@qnx.com] Sent: Sunday, May 24, 2009 10:21 AM To: sdpprereleases-community Subject: Probably application builder bug The application builder applications called from the command line cause the following error under 641M5: Ap: Unable to open resource file (/net/host_name.domain_name/) The same code works fine under 641M4 best regards _______________________________________________ QNX Software Development Platform Pre-Releases http://community.qnx.com/sf/go/post29918
How can I get m6? If I could I can check.
It seems that the bug was fixed in the final 6.4.1
