Trackers
Trackers
Forum Topic - Which loader to use for USB flash stick: (3 Items)
I am running QNX 6.3.2 on a Boxer computer type AEC-6920. The boot device is a 4 Gbyte partition on an 8 Gbyte CF flash
card. I have created a backup on a 4 Gbyte USB stick, and I try to make it bootable. The USB stick popped up as /fs/hd10
-dos-1 and as /dev/hd10t12. After umounting those, I did:
fdisk /dev/hd10 delete -a
fdisk /dev/hd10 add -s1 -t79 -b -p100
dinit -h /dev/hd10t79
I found a zero length .boot file in the root of the stick so I tried
dinit -f /x86/boot/sys/ipl-diskpc2 /dev/hd10t79
but found that dinit reported /x86/boot/sys/ipl-diskpc2-flop for the loader.
I swapped boot priority in the BIOS but no success in booting. Swapping back again, I did boot fron the CF card but
after some time I could select to mount either the CF or the USB stick as root. I mounted the USB stick as root and the
system continued to boot and works fine, but slower.
Now I compared the sizes of the .boot files in the root of both devices, the
stick .boot was 472 bytes and the CF .boot (that worked) was 1214560 bytes!
I copied the CF .boot (and the .altboot) to the stick and tried again. It
stopped at the BIOS message "Hit Esc for .altboot", which was partially
overwritten by characters and then nothing happened.
Where can I find a suitable .boot file? The stick is reported as vendor
0x090c (SMI Corporation), product 0x1000, (Mem-drive easyII) by the usb
utility.
Or must I build my own.ifs file?
Grateful for help
/Rune Larsson
Re: Which loader to use for USB flash stick
Instaed of
did you tried :
dloader /dev/hd0t79 pc2
>  4 Gbyte partition on an 8 Gbyte CF flash card. I have created a backup on a 4
> fs/hd10-dos-1 and as /dev/hd10t12. After umounting those, I did:
> again, I did boot fron the CF card but after some time I could select to mount
> the system continued to boot and works fine, but slower.
> utility.
> Grateful for help
> /Rune Larsson
No, I have not tried that.
AFAIK I need to build a .boot file with the appropriate drivers for the
stick.
Regards
/Rune
Jeevan Mathew skrev:
> Instaed of
> did you tried :
>> utility.
>> Grateful for help
>> /Rune Larsson
> http://community.qnx.com/sf/go/post27857
