Trackers
Trackers
Forum Topic - Exporting OpenGLes to Image : (6 Items)
Hello All,
I'm currently working on generating an openGLes drawing on a Ptraw in photon and would like to export this "image drawn
to a picture format like a png. I would like to avoid taking a screenshot with standard photon code, as this would cause
 the background to be the same as it is shown on the screen. It would be perfect if I could render one frame to an area
in memory with a white background and then dump call another function to write this to a PNG.
I have almost no OPENGL experience, but I have found some documentation saying that it is possible in openGL, but it is
not in OPENGLes, QNX's implementation of it.
Does anyone know if this is possible? A quick example or a list of the function calls would be perfect.
Kevin Raymond
Re: Exporting OpenGLes to Image
Since you are using a PtRaw widget, I assume that you have a gf_surface_t of your eglContext. You can get the surfaces
info by calling gf_surface_get_info(). Create an img_t structure based on the surface's info data (basically wrapping
it). Now you can call img_write_file().
-Misha.
> wrapping it). Now you can call img_write_file().
Thank you for your help, this is working nicely. However, the problem
we're running into is to save an img_t as a png with a transparent
background. Saving the surface as a png is easy enough, but we are not
able to get rid of the background.
Should this be happening on the surface or on the img_write_file()?
In other words, should the background be erased from the surface
or is the img library responsible for ignoring a specific color in the
surface?
I did try adding IMG_TRANSPARENCY to the img_t and specifying the
background color to no avail: it is always saved in the png. If you had
the time to provide a small example, I would be very grateful.
QNX needs more love on google search.
Taking a quick look at the png codec, it does not appear to check the transparency flag on a write operation ... but do
you really want transparency or alpha?
Could you not have a surface type of 8888 and write it out?
Thanks for the quick reply.
After doing more tests, I realized that the Photon Image Viewer doesn't
support transparent pngs. Loading my png with firefox gives a transparent
background while the image viewer gives me whatever background color I
had in the surface (from glClear()). ...am I making any sense here?
The last problem I'm having is that the same surface blitted to the PtRaw
gives a black background. It looks like the PgContextBlit() call doesn't
handle the alpha channel of the gf_surface. Do you have a hint on how to
do this?
For the record, here's what I have (error handling removed):
  gf_dev_t gf_dev;
  gf_dev_info_t info;
  gf_dev_attach(&gf_dev, 0, &info);
  gf_display_t gf_display;
  gf_display_info_t gf_display_info;
  gf_display_attach(&gf_display, gf_dev, 0, &gf_display_info);
  gf_surface_create(
    &g_gf_surface, gf_dev, 100, 100,
    gf_display_info.format, 0, 0);
  EGLDisplay display = eglGetDisplay(gf_dev);
  eglInitialize(display, 0, 0);
  EGLint attributes[] = {
    EGL_RED_SIZE, 8,
    EGL_GREEN_SIZE, 8,
    EGL_BLUE_SIZE, 8,
    EGL_ALPHA_SIZE, 8,
    EGL_NONE
  EGLConfig config;
  EGLint num_config = 0;
  eglChooseConfig(display, attributes, &config, 1, &num_config);
  EGLContext context =
    eglCreateContext(display, config, EGL_NO_CONTEXT, 0);
  EGLSurface surface =
    eglCreatePixmapSurface(display, config, g_gf_surface, 0);
  eglMakeCurrent(display, surface, surface, context);
  glMatrixMode(GL_PROJECTION);
  glLoadIdentity();
  glViewport(0, 0, 100, 100);
  glLoadIdentity();
  glEnable(GL_LINE_SMOOTH);
  glEnable(GL_BLEND);
  glBlendFunc(GL_ONE, GL_ONE);
  glOrthox(fix(0), fix(100), fix(0), fix(100), fix(-1), fix(1));
  glMatrixMode(GL_MODELVIEW);
  glLoadIdentity();
After this, I create a PtWindow containing a PtRaw:
  PtInit(0);
  PtArg_t args[4];
  PhDim_t dim = {100, 100};
  PtSetArg(&args[0], Pt_ARG_DIM, &dim, 0);
  PtSetArg(&args[1], Pt_ARG_WINDOW_TITLE, "", 0);
  PtWidget_t* window =
    PtCreateWidget(PtWindow, Pt_NO_PARENT, 2, args);
  PtSetArg(&args[1], Pt_ARG_RAW_DRAW_F, raw_draw, 0);
  PtWidget_t* raw = PtCreateWidget(PtRaw, Pt_DFLT_PARENT, 2, args);
  // g_context is a PdOffscreenContext_t*
  g_context = PdCreateOffscreenContextGF(g_gf_surface);
Here's the draw function (where draw_rect() is a wrapper around
glDrawArrays with GL_TRIANGLE_STRIP):
  glColor4f(0.0, 0.0, 1.0, 0.5);
  draw_rect(20, 20, 70, 70);
  glColor4f(0.0, 1.0, 0.0, 0.5);
  draw_rect(30, 30, 90, 50);
  PhRect_t src_rect = {{0, 0}, {100, 100}};
  PhRect_t dest_rect = {{0, 0}, {100, 100}};
  PgContextBlit(g_context, &src_rect, PhDCGetCurrent(), &dest_rect);
  gf_surface_info_t info;
  gf_surface_get_info(g_gf_surface, &info);
  img_t img;
  memset(&img, 0, sizeof(img_t));
  img.access.direct.data = info.vaddr;
  img.access.direct.stride = info.stride;
  img.w = info.w;
  img.h = info.h;
  img.format = gf_to_img_format(info.format);
  img.npalette = info.palette.ncolors;
  img.palette = info.palette.colors;
  img.flags =
    IMG_FORMAT | IMG_W | IMG_H | IMG_DIRECT | IMG_PALETTE;
  img_write_file(ilib, "test.png", 0, &img);
What display mode are you in, 8888?
For the blit operation, I believe you have to use PgSetAlpha().  If you don't turn on some sort of alpha operation, the
pixels just get pounded into the frame buffer - i.e. they don't get "alpha'ed" with what is behind them.
