Trackers
Trackers
Forum Topic - Current process printf: (13 Items)
I want to be able to tell which process a piece of code is running in so that I can connect to that process to debug it.
  I can use printfs to output information from the running code.  Is there a call or method I can use to determine in
which process I am running?
Ant
Re: Current process printf
Try this:
printf ("%d\n", getpid());
it.  I can use printfs to output information from the running code.  Is there a call or method I can use to determine in
> Thanks
> Ant
> http://community.qnx.com/sf/go/post8685
Thank you!
Ant
> Try this:
I am using this during the startup and getting the process ID printed as expected but the process is not listed when I
run pidin after startup.  I suspect that the process is no longer running.  Is there a call that will turn that ID into
a process name?
Ant
Ant Pace wrote:
>> Try this:
 a process name?
What would be the process name? Binary path? What is the point of that, you probably already know it.
Do you suspect your process is crashing? If so, have you checked if the process left a core behind? To determine where
your core file would be located, see how is your dumper service started. The command line should reveal the destination
path for cores.
If it is not crashing, add some more 'printf's to figure out if it's getting to the point you believe it does... I would
 start from there.
No I am sure that the code is working as expected I just want to develop it further and don't know which process is
running that code.  When I use pidin I see the short name, eg  opt/bin/antcode.  That is the information I want.  If I
had written the code then I would know in which process it is running, but it is adopted code.  I want to know which
process it is so that I can attach to the process with the debugger.
Ant
Ah!  I have found __progname which gives me a name.  I think it is the name of the process.
RE: Current process printf
You can also do this:
printf ("%d %s\n", getpid(), argv[0]);
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
Then sorry, I do not understand what you are asking.
To try to just answer the question: in your main, you can do
printf("%s\n", argv[0])
and get the binary path.
But what confuses me is, if you can put printf in your code, compile it into a binary and run it, then how come you
don't know which process is running that piece of code... if you could clarify a bit what exactly you are trying to do,
maybe I could help.
I have joined a team and there are hundreds of source files and I haven't worked out a method of finding which code is
in which process yet.  I see that there are clues in the makefiles.
argv[0] *does* print the name but this is like a standalone program.  I haven't used QNX or Unix based systems before.
It feels as though the embedded RT system is starting a standalone program.  I suppose if it can be run from a console
connection there is no reason that the embedded code can't do the same.  If that guess is right does that mean that the
standalone program would run in a process that is then not seen with pidin after the program finishes?
Would it be normal for an embedded program to start a standalone program?
Thanks for your help so far, I do appreciate it.
Ant
How do you define "embedded program" ? (sorry, the terminology is new to me).
It is possible for a program to spawn another program which, in turn, gets its own PID just as if you started it from a
shell. Maybe that is what is going on.
Embedded program: code that runs in an embedded system.
I think it is I that need to change the way I think.  I am used to writing code which is compiled to a binary that the
processor runs.  Once the code is written there is little concept of a 'program', just machine code.  I have used
'other' RTOSs that have tasks but not further programs.  That feels very un-real-time to me - more like DOS or Windows
where there is no real realtime.
I am used to a task switch taking the order of microseconds.  Can you give me a very rough idea of how long it takes to
'spawn another program'?  My code runs during startup so does not need to be real time - presumably why the original
programmer chose to make a separate program rather than run it inline in the parent process.
In fact could you give me a feel for the difference between interprocess and intertask communication?  Presumably
intertask comms is quicker?
Thanks again
Ant
Ah, ok.
Then I think it will be easy once you realize Neutrino is POSIX os, so if you ever programmed for unix-es, you'll know
how things work.
to 'spawn another program'?  My code runs during startup so does not need to be real time - presumably why the original
No, sorry, I can not give you that idea - the only thought I have is to suggest making an example and do some timings.
I suggest you read this:
http://www.qnx.com/products/neutrino_rtos/
and search a bit around our web-site, it has A LOT of good information. This is not to say you shouldn't be using the
forum any more :-)
