Trackers
Trackers
Forum Topic - tracing user events: (5 Items)
tracing user events
When running tracelogger with these filter options, it seems that the USREVENTS are not captured. This seems incorrect,
because USREVENT is different class than the ones that get filtered with F1 to F7. Enabling one of the options also
starts recording the USREVENT class.
Test it with:
tracelogger -F1 -F2 -F3 -F4 -F6 -F7 -s 3
./start_your_program_that_uses_trace_logi_while_trace_gets_logged
traceprinter | grep USREVENT
Re: tracing user events
How many user events did you emit?  Did you stop tracelogger? Sounds
like the buffer wasn't flushed.
, because USREVENT is different class than the ones that get filtered with F1 to F7. Enabling one of the options also
> Test it with:
> http://community.qnx.com/sf/go/post106486
> To cancel your subscription to this discussion, please e-mail momenticsgs-community-unsubscribe@community.qnx.com
I emitted about 12 user events. However, since I run tracelogger with the option of '-s 3', I assume that it would force
 a buffer flush before it terminates, woudn't it?
  Sebastian
Which version of tracelogger are you using?  There was a fix made in
2011 that addressed this.
Try adding TraceEvent(_NTO_TRACE_FLUSHBUFFER) to your app...
force a buffer flush before it terminates, woudn't it?
>    Sebastian
> http://community.qnx.com/sf/go/post106489
I use 6.5.0 SP1.
Adding the explicity flush solves the problem. Thanks.
> option of '-s 3', I assume that it would force a buffer flush before it
> >    Sebastian
> > QNX Momentics Getting Started
