Trackers
Trackers
Forum Topic - Building for QNX and Linux: (6 Items)
I have some software that needs to run on both QNX Neutrino and Linux. Using command line tools and custom makefiles
works fine, however I would like to take advantage of the IDE's functionality. Unfortunately, I see no obvious way to
add a "Linux target" to a QNX-Project. Also, the standard QNX-Makefiles won't work on machines without the  QNX-specific
 tools and files (recurse.mk,...).
Is there a standard / preferred way to build for both QNX and a different OS?
Any help will be greatly appreciated!
RE: Building for QNX and Linux
> From: Thomas Buschmann [mailto:buschmann@amm.mw.tum.de]
> Sent: October 15, 2007 5:14 AM
> To: momenticsgs-community
> Subject: Building for QNX and Linux
> QNX-specific tools and files (recurse.mk,...).
> a different OS?
For the most part, the IDE is just sitting on top of your custom
build file functionality.  If you want to tie yourself to the IDE
then I would suggest that you look at the Managed Makefile type
of project.  This project allows different project and build
configurations that use different toolchains.  It solves a problem
similar to the QNX Makefiles, but in an IDE specific manner.  The
Managed Makefile project is a standard part of the Eclipse CDT.
For the command line, the closest thing to a "standard" would be to
use a "configure/make" style build, which can be incorporated into
a QNX makefile structure (see the QNX Programmer's Guide in the
makefile appendix for more details ... or look at the OS source for
something like ports/tar).
Of course, if the software is going to run under Neutrino and Linux,
then you should already have the Neutrino dev environment installed!
Nobody would want to only build the software for Linux I'm sure =;-)
Hope this helps,
 Thomas
Re: RE: Building for QNX and Linux
Thanks for the quick response. I guess, since I need the flexibility of
compiling on and for different systems with different toolchains, I won't get around writing a
custom Makefile. At least until everybody starts using QNX ;)
I'm just trying to do *really* basic open-source development, and feel I'm sinking into quicksand....with the kinder/
gentler/developer friendly 6.4 running natively on x86.
I've been trying for 2 days to make the 'tinyxml' package, http://sourceforge.net/projects/tinyxml, which in turn
requires GNU autoconf, which in turn requires m4, which in turn requires Perl5.  I tried to download and build Perl5 and
 got very cryptic errors, including some in hints/qnx.sh and otherwise.
So I went through the whole BSD 'bootstrap' process to create the package utils, and then when I go into lang/perl5 and
type 'make' I get a syntax error.
sheesh!  isn't there a way to just do 'pkgadd' of something as ubiquitous as Perl?
thanks in advance -
Chris
RE: RE: Building for QNX and Linux
Binaries can be found at:
ftp://ftp.netbsd.org/pub/pkgsrc/packages/QNX/i386/6.4.0_head_20081005/
For newbies at building packages, that can be a frustrating experience.
I could not find tinyxml though.  However I remember taking just the source and pretty much included them as is in my
program without too much problem.
Meanwhile I've switch to Poco, not as tiny though, but Poco supports QNX6 right out of the box.
> From: Chris Nicholas [mailto:community-noreply@qnx.com]
> Sent: January-13-09 6:16 PM
> Subject: Re: RE: Building for QNX and Linux
> I'm sinking into quicksand....with the kinder/gentler/developer
> http://sourceforge.net/projects/tinyxml, which in turn requires GNU
> tried to download and build Perl5 and got very cryptic errors,
> package utils, and then when I go into lang/perl5 and type 'make' I get
> a syntax error.
> ubiquitous as Perl?
> thanks in advance -
> Chris
> http://community.qnx.com/sf/go/post19995
and type 'make' I get a syntax error.
Sounds like you're talking about pkgsrc?  You need to use bmake.
See this page:
http://community.qnx.com/sf/wiki/do/viewPage/projects.pkgsrc/wiki/BinaryPackages
Which describes:
# PKG_PATH=ftp://ftp.netbsd.org/pub/pkgsrc/packages/QNX/i386/6.4.0_head_20081005/All # PKG_PATH=ftp://ftp.netbsd.org/pub
/pkgsrc/packages/QNX/i386/6.4.0_head_20081005/All pkg_add -v perl
