Community
Tracker
Forum Topic - Photon ApBuilder crashes when using PtPane: (3 Items)
Photon AbBuilder abruptly closes when using the Module Tree to move widgets in or out of a PtPane.
If you save after each operation it does not close or crash.  If you move more than one or two widgets out of a PtPane,
 it will surely close, losing your changes, and ocassionally corrupting the workspace.
I am working with Neutrion 6.3 and the About screen on Photon ApBuilder says version 2.03. This is with Version: 4.0.1
Build id: I20070321 of the Momentics IDE.
I am working on a Windows XP Pro platform with SP2.
raywert@swbell.net
Re: Photon ApBuilder crashes when using PtPane
I will forward you message to someone that can help, it may be as simple as upgrading to a newer release, but we will
find out shortly.
RE: Photon ApBuilder crashes when using PtPane
I tried to reproduce this problem in 6.3.0 SP1/SP2 using a small PhAB application and could not. In order to help you, I
 will need a PhAB project which demonstrates this problem.
You can send me the required files and information at: mfeil@qnx.com
Please note that I also tried moving widgets in the Module Tree in 6.4.0 Windows Momentics and it does not work - the
Photon server crashes even on simple moves. I created PR64527 to track this 6.4.0-only problem.
Max
Sent: Thursday, January 08, 2009 7:09 PM
To: momentics-community
Subject: Photon ApBuilder crashes when using PtPane
raywert@swbell.net
http://community.qnx.com/sf/go/post19703
