Community
Tracker
Forum Topic - Linking a C library from C++ project : Page 1 of 2 (12 Items)
I'm trying to use the MySQL 5 client to access a database running on another machine.  I'm hosting on Windows Vista
Momentics 4.01 and targeting 6.3.2 Neutrino running on a separate x86 box.  I've tried both the 2.95 and 3.3 compiler
tool sets.
When I link from a C project everything is fine.  When I link from a C++ project I get a number of undefined reference
errors (obviously due to name mangling).  In the MySQl header file there is the expected #ifdef __cplusplus extern "C" {
 code.  I would have expected this to work correctly, but it isn't.
I have run into this with gcc previously with another library.  Not sure what is going on.
Any ideas of how to fix this?
Thanx
Tim
Re: Linking a C library from C++ project
Here is the command line for the linker:
C:/QNX632/host/win32/x86/usr/bin/qcc -V3.3.5,gcc_ntox86  -lang-c++ -lang-c++    -oC:/Users/Tim.DELTA/Documents/
EclipseWorkspace/Test/x86/o/Test    Test.o  -L. -LC:/QNX632/target/qnx6/x86/lib/mysql -LC:/QNX632/target/qnx6/x86/lib -
LC:/QNX632/target/qnx6/x86/lib/gcc/3.3.5 -LC:/QNX632/target/qnx6/x86/lib -LC:/QNX632/target/qnx6/x86/usr/lib    -Bstatic
    -lmysqlclient_r    -Bdynamic
I can't see any problems (though the double -lang-c++ seems unusual)
Thanx
RE: Linking a C library from C++ project
Hi Tim,
You'll want to extern "C" your function implementation as well. I've
attached a sample applcation that does the following:
Main program links in shared library, which links in a static library.
Main program links in a C++ shared library (jtlcpp.cc and jtlcpp.h).
// Idle question: I wonder how many bounces I'll get for sending a .zip
file.
Cheers,
-Brian
Sent: Monday, April 28, 2008 12 28
To: momentics-community
Subject: Re: Linking a C library from C++ project
-oC:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/x86/o/Test    Test.o
-LC:/QNX632/target/qnx6/x86/lib/gcc/3.3.5 -LC:/QNX632/target/qnx6/x86/lib
-LC:/QNX632/target/qnx6/x86/usr/lib    -Bstatic    -lmysqlclient_r
-Bdynamic
Thanx
http://community.qnx.com/sf/go/post7399
Attachment: Text jtl-test-project.zip 16.15 KB
> machine.  I'm hosting on Windows Vista Momentics 4.01 and targeting 6.3.2
> compiler tool sets.
> project I get a number of undefined reference errors (obviously due to name
> extern "C" { code.  I would have expected this to work correctly, but it isn't
> is going on.
Hi Tim,
Are the undefined references errors for the symbols that should have C linkage? Can you use nm on both the C++ object
and the library to confirm they have C linkage ?
Can you post the linker output as well?
Ryan Mansfield
And my example was completely bass-ackwards. Sorry about that.
Sent: Monday, April 28, 2008 12 37
another
> compiler tool sets.
name
__cplusplus
isn't
what
> is going on.
Hi Tim,
linkage? Can you use nm on both the C++ object and the library to confirm
Ryan Mansfield
http://community.qnx.com/sf/go/post7402
Re: RE: Linking a C library from C++ project
Thanx!
Interestingly if I undefine __cplusplus before including the mysql header the only undefined references are to the mysql
 functions I call.
If I do not undefine _cplusplus before including the mysql header the undefined references are to a number of other
libraries including socket, m, <taocrypt?>, etc. along with __pure virtual and __builtin_delete.
The output of nm for the app object is (with __cplusplus defined)
C:\Users\Tim.DELTA\Documents\EclipseWorkspace\Test\x86\o-g>\QNX632\host\win32\x86\usr\ntox86\bin\nm.exe --no-demangle
test.o
         U __gxx_personality_v0
00000000 T main
         U mysql_close
         U mysql_error
         U mysql_init
         U mysql_real_connect
and the library is similar for these functions.  There are some mangled names in the library from what appears to be the
 taocrypt library.
I have attached the output of nm for the library as it is very long.
I'm not very familiar with using nm so please let me know if the output is not what you are looking for.
Thanx
Tim
Attachment: Text nm.out 317.19 KB
Here is the linker output
make -k EXTRA_SUFFIXES=cpp  clean all --file=C:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/QMakefile51860.tmp
make -j 1 -Cx86 -fMakefile clean
make[1]: Entering directory `C:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/x86'
make -j 1 -Co -fMakefile clean
make[2]: Entering directory `C:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/x86/o'
C:/QNX632/host/win32/x86/usr/bin/rm -f  Test  *.pinfo *.o *.err *.map mapfile *.sym *.i
make[2]: Leaving directory `C:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/x86/o'
make -j 1 -Co-g -fMakefile clean
make[2]: Entering directory `C:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/x86/o-g'
C:/QNX632/host/win32/x86/usr/bin/rm -f  Test_g  *.pinfo *.o *.err *.map mapfile *.sym *.i
make[2]: Leaving directory `C:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/x86/o-g'
make[1]: Leaving directory `C:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/x86'
make -j 1 -Cx86 -fMakefile all
make -j 1 -Co -fMakefile all
C:/QNX632/host/win32/x86/usr/bin/qcc -V3.3.5,gcc_ntox86 -c -Wc,-Wall -Wc,-Wno-parentheses  -O          -DNDEBUG   -I. -
IC:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/x86/o -IC:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/x86 -IC:/
Users/Tim.DELTA/Documents/EclipseWorkspace/Test -IC:/QNX632/target/qnx6/usr/include       C:/Users/Tim.DELTA/Documents/
EclipseWorkspace/Test/Test.cpp
C:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/Test.cpp: In function `int
   main(int, char**)':
C:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/Test.cpp:21: warning: unused
   variable `const char*str'
C:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/Test.cpp:23: warning: unused
   variable `long int l'
C:/QNX632/host/win32/x86/usr/bin/rm -f  C:/Users/Tim.DELTA/Documents/EclipseWorkspace/Test/x86/o/Test
C:/QNX632/target/qnx6/x86/lib/mysql/libmysqlclient_r.a(client.o): In function `my_connect':
client.o(.text+0x2b): undefined reference to `connect'
client.o(.text+0x65): undefined reference to `connect'
C:/QNX632/target/qnx6/x86/lib/mysql/libmysqlclient_r.a(client.o): In function `wait_for_data':
client.o(.text+0x1bf): undefined reference to `getsockopt'
C:/QNX632/target/qnx6/x86/lib/mysql/libmysqlclient_r.a(client.o): In function `mysql_real_connect':
client.o(.text+0x1c42): undefined reference to `socket'
client.o(.text+0x1dc5): undefined reference to `socket'
C:/QNX632/target/qnx6/x86/lib/mysql/libmysqlclient_r.a(viosocket.o): In function `vio_fastsend':
viosocket.o(.text+0x1fe): undefined reference to `setsockopt'
viosocket.o(.text+0x220): undefined reference to `setsockopt'
C:/QNX632/target/qnx6/x86/lib/mysql/libmysqlclient_r.a(viosocket.o): In function `vio_keepalive':
viosocket.o(.text+0x27a): undefined reference to `setsockopt'
C:/QNX632/target/qnx6/x86/lib/mysql/libmysqlclient_r.a(viosocket.o): In function `vio_close':
viosocket.o(.text+0x320): undefined reference to `shutdown'
C:/QNX632/target/qnx6/x86/lib/mysql/libmysqlclient_r.a(viosocket.o): In function `vio_peer_addr':
viosocket.o(.text+0x3d1): undefined reference to `getpeername'
C:/QNX632/target/qnx6/x86/lib/mysql/libmysqlclient_r.a(viosocket.o): In function `vio_timeout':
viosocket.o(.text+0x47e): undefined reference to `setsockopt'
C:/QNX632/target/qnx6/x86/lib/mysql/libmysqlclient_r.a(ssl.o): In function `TaoCrypt::Block<unsigned char, TaoCrypt::
AllocatorWithCleanup<unsigned...
Are you using the binary distribution of the MySQL Client 5.0? I believe that was compiled for a QNX 6.2.1 system which
means it was compiled with a gcc 2.95.3 compiler. If you are using the binary distribution, then you will not be able to
 link your 3.3.5 project against the mysql libs as the the C++ ABI was completely changed (including the name mangling
scheme) between 2.95.3 and 3.3.5.
What errors did you encounter when you tried to using 2.95.3?
Ryan Mansfield
Yes I am using the binaries and they are compiled for 6.2.1.
Switching to the 2.95 toolset removes the __pure_virtual and __buildin_delete references.
The other 'undefined references' are removed by adding socket and 'm' libraries.
So now it links and works.
Not sure why I have to add the socket and 'm' libraries with the C++ compiler and not with the C compiler?
Thanx for the help.
Tim
