Trackers
Trackers
Forum Topic - qcc for QNX v6.5.0 vs qcc for v6.3.2 v: qcc doesn't accept -std=C99 option: (5 Items)
I have to study a software that compiles under v6.3.2 with no errors.
The problem is that when try to compile it under v6.5.0 several compiler errors occur, for example: 'comma at end of
enumerator list'.
In other forums I see that the upwritten error can be avoided with the compiler option '-std=c99', but when I try to use
 it the qcc give me the following error:
cc: unknown option: '-std=c99'
I tried also to compile using the command line outside Momentics, but the error is the same so this error is not related
 to the makefile.
Can you help me?
Re: qcc for QNX v6.5.0 vs qcc for v6.3.2 v: qcc doesn't accept -std=C99 option
Try with -Wc,-std=c99
Aleksandar
enumerator list'.
use it the qcc give me the following error:
related to the makefile.
> Can you help me?
> http://community.qnx.com/sf/go/post88676
Also typing
qcc.exe -Wc -std=c99
the same error message appears:
> Aleksandar
> errors occur, for example: 'comma at end of enumerator list'.
> compiler option '-std=c99', but when I try to use it the qcc give me the
> following error:
> error is the same so this error is not related to the makefile.
> > Can you help me?
Aleks suggested -Wc,-std=c99 and you took out the comma and replaced it with a space.
Ryan Mansfield
>  space.
> Regards,
> Ryan Mansfield
Oh ... my mistake!
With the comma it works.
Thank you all!
