Trackers
Trackers
Forum Topic - source code of devi-hid and io-hid: (6 Items)
I have searched all over the project codes and cannot find the source code for devi-hid, can anyone kindly tell me where
 it is located ?
Re: source code of devi-hid and io-hid
>  devi-hid, can anyone kindly tell me where it is located ?
> Thanks
Its not currently published, is there something in particular that you are having troubles with?
Best regards,
Erick
hi!
Thanks for the reply, I have a usb keyboard device that has F13 to F17 keys, but I find out that the current devi-hid
only support keys up to F16. If I press the F17 key, my program only gets some invalid key codes.
Therefor I would be grateful to know whether there's a solution that can make my program receive F17 correctly.
Thanks !
Best Regards,
John
Is there a chance that devi-hid will support F17 and other USB Keyboard usages in 6.4.2 ?
> for
> > Thanks
> Best regards,
> Erick
Likely not as I don't have a keyboard here that has keys upto F17 on it :)
Is the scancode a valid code?
http://download.microsoft.com/download/1/6/1/161ba512-40e2-4cc9-843a-923143f3456c/translate.pdf
Put the input driver into a high level of verbosity (devi-hid -vvvvvvvv kbd) and you should see what the driver is
picking up.  If the scan codes are valid (which I expect that they should be) then its just a matter of updating your
keyboard map with something that recognizes those scan codes.  The keyboard map files are located in /usr/photon/
keyboard
The .kdef file is the compilable definition file that you would have to make your changes in.
Best regards,
Erick
>  in 6.4.2 ?
> > for
> > > Thanks
> > Hi,
> > Best regards,
> > Erick
Hi! Thanks for the information!
After I use follow your method, I find out that the key_sym and key_cap field of F17 is correct now, which is 0xF0CE.
However, the scan code field is still 0, while F13 is 0x59, F14 is 0x5E, F15 is 0x5D and F16 is 0x5F. Those definitions
are a little different from those defined in the Microsoft document. So I am wondering that if they can be redefined to
match the document, and also add supports for F17 in the future ? :)
Best Regards,
John
> and you should see what the driver is picking up.  If the scan codes are valid
> map files are located in /usr/photon/keyboard
> your changes in.
> Best regards,
> Erick
> usages
> >  in 6.4.2 ?
> code
> > > for
> > > > Thanks
> > > Hi,
> > > Best regards,
> > > Erick
