Pavel Ustinov
Problem with RTL8168 Network card driver
Pavel Ustinov
06/09/2009 3:43 AM
post31181
Hi!
I tried to use new Net.rtl8169 driver with my onboard Network card (motherboard ASRock ConRoe1333-DVI/H), and my
approach failed.
Driver I used is from topic (http://community.qnx.com/sf/discussion/do/listPosts/projects.community/discussion.
qnx4_community_support.topc2891)
I started:
Net &
Net.rtl8169 -d 8168 -v -V 10ec &
But nothing happened.
Net.rtl8169 Run and Done ...
I tried different combination of parameters (irq, port, pci index), but nothing helped.
That is my:
#show_pci -v
Vendor ID = 10ech,
Device ID = 8168h,
PCI index = 0h
Class Code = 020000h Network (Ethernet) ProgIF=0
Revision ID = 2h
Bus number = 1
Device number = 0
Function num = 0
Status Reg = 10h
Command Reg = 7h
Latency Timer = 0h
Cache Line Size= 8h un-cacheable
Base Address = IO@e800h length 256 bytes MEM@fdeff000h,Prefetchable,64bit length 4096 MEM@fdee0000h,Prefetchable,64bit
length 65536
Subsystem Vendor ID = 1849h
Subsystem ID = 8168h
Expansion ROM = febf0000h length 65536 disabled
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = 1, INT A
Interrupt line = 10
How can I start driver?
Thanks in advance
