Community
Tracker
Forum Topic - USB & Fsys.umass problem getting access to device under 4.25: (8 Items)
Trying to get USB memory stick to work.
Using QNX 4.25 with USB 2.0 package installed.
Using Ampro motherboard (82801 DBM I/O hub) with both USB v2.0 EHCI and UHCI v1.1.
Using
   #io-usb
I get the 'usb' entry under /dev (this is the stack/driver?)
Using
   #usb
I can see either a full speed USB memory stick under the UHCI interface, or a high speed under the EHCI interface.
Then trying the
   #Fsys.umass
it seems to recognize the device and there are no errors, but no new device like 'usb0' shows up.
Is there a trick to this final step to get the device available?
Process list seems fine (have io-usb and Fsys.umass).
I have tried numerous combinations, but nothing changes.  Always get the usb stack, but nothing more.
Re: USB & Fsys.umass problem getting access to device under 4.25
Using the syntax:
   Fsys.umass fsys -l -n Direct-Access=usb
I can get a usb0 to show up in /dev.
However, I can seem to do anything with it.  A mount like:
   mount /dev/usb0 /fs/usb
justs hangs.
The USB memory stick's light is on.
Had lots of issues with this stuff as well
try Fsys.umass......
sleep 2
mount -p /dev/usb0
sleep 3
mount -t dos /dev/usb0t12 /dos/e
This assumes that your USB has partitions
I also have this problem. but My question is when I use 'Fsys.umass... ', the return is 'no Adaptors fount!'.what  can I
 do for the case?  thanks very much!
RE: USB & Fsys.umass problem getting access to device under 4.25
Please post the output from 'show_pci -v' so that we can see what USB
adapters you have.
From: zhang shilei [mailto:community-noreply@qnx.com]
Sent: Wednesday, August 19, 2009 11:06 PM
To: qnx4-community
Subject: Re: USB & Fsys.umass problem getting access to device under
4.25
', the return is 'no Adaptors fount!'.what  can I do for the case?
thanks very much!
QNX4 Community Support
http://community.qnx.com/sf/go/post36351
Re: RE: USB & Fsys.umass problem getting access to device under 4.25
I have also this problom.
run "shoe_pci -v", get:
Vendor ID = 8086h, INTEL CORPORATION
Device ID = 7112h,
PCI index = 0h
Class Code = 0c0300h Serial Bus (Universal Serial Bus) ProgIF=0
Revision ID = 0h
Bus number = 0
Device number = 7
Function num = 2
Status Reg = 280h
Command Reg = 5h
Latency Timer = 40h
Cache Line Size= 0h
IO@1060h length 32 bytes
Subsystem Vendor ID = 15adh
Subsystem ID = 1976h
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = 4
PCI Int Pin = INT D
Interrupt line = 9
what can I do for this?
Thank you!
Hi wang,
Do you use the latest version from the QNX4 Project?
http://community.qnx.com/sf/wiki/do/viewPage/projects.qnx4/wiki/SoftwareUpdates2010
> Device ID = 7112h,
> PCI index = 0h
> Revision ID = 0h
> Bus number = 0
> Device number = 7
> Function num = 2
> Status Reg = 280h
> Command Reg = 5h
> Latency Timer = 40h
> Cache Line Size= 0h
> Max Lat = 0ns
> Min Gnt = 0ns
> PCI Int Pin = 4
> PCI Int Pin = INT D
> Interrupt line = 9
> Thank you!
I had lots of trouble with this. Here is a script I have devised to open different USB sticks. I have several sticks
with specific items on them. Each manufacturer seems to have a different device name.
  use vedit and put this into a file I call it "loadusb" then put it in the /usr/local/bin directory. Use chmod +x to
make it executable.
#! /bin/ksh
# Use this file to mount a usb memory stick may be run using ./memstick then
# finishing command manually depending on the type partition on the device
io-usb &
Fsys.umass -v fsys -Nusb -nusb0. &
mount -p /dev/usb0.0             	 # check /dev/to see partiton type
sleep 2
slay -fQ Dosfsys                     	 # needed before running Fatfsys.
slay -fQ Fatfsys                     	 # needed if Fatfsys is running from sysinit.
Fatfsys e=`ls /dev/usb0.0t*`
sleep 1
echo ""
echo "    USB device loaded as /dos/e"
echo ""
 Use this script to unmount it so if you want to install another disk you can do it without rebooting; Make sure you put
 it in the same directory as above and make it executable.
#! /bin/sh
# makes it safe to remove a usb stick and allows reinstall without reboot
sync
umount /dos/e
umount /dev/usb0.0
rm /dev/usb0.0
slay -f io-usb
sleep 2
echo ""
echo "    Safe to remove USB device"
echo ""
I can post a tar file with both files later if you need them
Brad
