Jack Zhang
AMD T16R Graphic Driver Problem
Jack Zhang
02/26/2018 11:44 AM
post118623
Hi Oleg,
I'm trying to install the latest experimental Install CD to the Advantech motherboard PCM-3356(cpu:AMD T16R). But I
can't make it. It can not boot into Photon, due to there is no corresponding graphic driver. Will you please help me
with this, I really appreciate any help from you, Thank you!
Jack
Jack Zhang
Re: AMD T16R Graphic Driver Problem
Jack Zhang
02/26/2018 12:17 PM
post118624
I have already used crttrap trap in the text mode to detect the graphic driver and I have attached the crt file. I have
tried the Hydra.ms/Pg.flat drivers but none of them is working.
Attachment: |
crt.5
9.35 KB
Oleg Bolshakov
Oleg Bolshakov
02/27/2018 5:29 AM
post118626
Hi Jack,
Can you attach here the show_pci -vvv from PCM-3356? Didn't you forget to copy appropriate Hydra.ms/Pg.flat lines to the
first line in your crt.<NODE> file? Did you reboot after executing of crttrap before launching ph? Try to use lines
with Pg.flatdc32 and standard graphics modes (like 1280x1024x32 and so on). Also you can try to add additional keys -r
or -e to Hydra.ms options.
26 февр. 2018 г., в 20:17:03, Jack Zhang <community-noreply@qnx.com> написал:
have tried the Hydra.ms/Pg.flat drivers but none of them is working.
> QNX4 Community Support
> http://community.qnx.com/sf/go/post118624
> To cancel your subscription to this discussion, please e-mail qnx4-community-unsubscribe@community.qnx.com
> <crt.5>
Jack Zhang
Jack Zhang
02/27/2018 7:30 AM
post118627
Hi Oleg,
I really appreciate your help, I have attached the show_pci output file, please help me to check it.
Besides, I have tried every different display resolution line in the crt.5, it seems still not work. And I reboot the
motherboard after executing of crttrap before launching ph.
Sincerely
Jack
Oleg Bolshakov
Oleg Bolshakov
02/27/2018 8:35 AM
post118628
Can you describe in detail what you see after launching ph command?
Do you have remote access (telnet or ditto) to this system? Try to start ph remotely and attach here the output if any.
27 февр. 2018 г., в 15:30:39, Jack Zhang <community-noreply@qnx.com> написал:
> Hi Oleg,
> Sincerely
> Jack
> http://community.qnx.com/sf/go/post118627
> <show_pci>
Jack Zhang
Jack Zhang
02/27/2018 10:19 AM
post118629
Hi Oleg,
There is no remote access to this device, I can descript it. I reinstall the OS again, and I choose to probe the video,
but it can't be applied with the selected resolution config, then I press the F3 to exit. You know at this time, the crt
.5 had been created, then I copy the 1028x768x8 line to the first line. Last, I change the OS boot into text
mode(picture 01), input the ph, then it boots into the Photon same as the picture 02. But you can see it, it is abnormal
, it is freezed, and I can't use the USB keyboard.
If i don't change it to text mode, it will stuck at Waiting for input driver..., same as the picture 03.
Sincerely
Jack
Oleg Bolshakov
Oleg Bolshakov
02/28/2018 3:48 AM
post118631
Hi Jack,
I see that you don't have graphics driver problem, but input drivers problem. Graphics seems to work fine.
Can you attach your input.<NODE> file? Which input devices do you use (keyboard, mouse)?
27 февр. 2018 г., в 18:19:38, Jack Zhang <community-noreply@qnx.com> написал:
> Hi Oleg,
, but it can't be applied with the selected resolution config, then I press the F3 to exit. You know at this time, the
crt.5 had been created, then I copy the 1028x768x8 line to the first line. Last, I change the OS boot into text
> Sincerely
> Jack
> http://community.qnx.com/sf/go/post118629
> <03.jpg><01.jpg><02.jpg><sysinit.5>
Jack Zhang
Jack Zhang
02/28/2018 5:55 AM
post118632
Hi Oleg,
First of all, thank you for your help. You are right, in fact it is the input driver problem. The system stuck at
loading the input driver, due to wrong input driver. Then I told the RD to change the bios to emulate USB keyboard.
Do you have any advice about how to use usb keyboard in Photon?
I note that it is ok to use usb keyboard in shell, but now it is not work in photon, is there any steps that I have
forgotten?
I connect one usb keyboard to this motherboard only!
Sincerely
Jack
Oleg Bolshakov
Oleg Bolshakov
02/28/2018 8:05 AM
post118634
I guess the problem may be in:
If you don't have the mouse you have to change default input.<NODE> file. It seems that you have forgotten to attach
yours. But if this is your issue you have to remove mouse from config. Change:
kbd fd -d/dev/kbd ps2 -r kb -2
to:
kbd fd -d/dev/kbd
28 февр. 2018 г., в 13:55:01, Jack Zhang <community-noreply@qnx.com> написал:
> Hi Oleg,
forgotten?
> Sincerely
> Jack
> http://community.qnx.com/sf/go/post118632
Jack Zhang
Jack Zhang
02/28/2018 8:03 AM
post118633
Hi Oleg,
The Input.node file is attached. And when I run 'io-usb -d ohci pindex=1', nothing is done, and there is no usbkbd0 file
under /dev.
Sincerely
Jack
Oleg Bolshakov
Oleg Bolshakov
02/28/2018 8:10 AM
post118635
You do not need to use USB if keyboard works in text mode. It seems that you use the USB legacy mode on. Do not add
Input to input.<NODE> file, change it to:
kbd -R fd -d/dev/kbd
28 февр. 2018 г., в 16:03:11, Jack Zhang <community-noreply@qnx.com> написал:
> Hi Oleg,
file under /dev.
> Sincerely
> Jack
> http://community.qnx.com/sf/go/post118633
> <Input.5>
Jack Zhang
Jack Zhang
02/28/2018 12:07 PM
post118636
Hi Oleg,
Thank you for your professional guidance, everything is running well. I really appreciate for your help!
Best Regards
Sincerely
Jack
