Trackers
Trackers
Forum Topic - accessing encrypted USB device: (9 Items)
I'm trying to get a McAfee encrypted USB stick to be usable under QNX4.  I have succeeded to a certain extent, but not
to the extent of being able to remove the device and subsequently re-insert it and be able to access it.  In particular
I'm performing the following steps:
1) Insert disk and finger-swipe to authenticate.
2) # io-usb
   At this point, the output of usb shows that the device is recognized.
3) # Fsys.umass
   At this point, the device /dev/hd1 is created.
4) # Fatfsys
   At this point, the encrypted portion of the disk is accessible as /dos/c.
   The unencrypted read-only portion does not appear.
5) # slay Fatfsys
   /dos/c disappears.
6) # slay Fsys.umass
   /dev/hd1 still exists.
7) # rm /dev/hd1
8) # slay io-usb
9) Remove and re-insert disk, and authenticate.
10) # io-usb
11) # Fsys.umass
    => "Can't attach to Fsys (Resource busy)
Any way I can recover?  I'm using the July 2010 USB stack.
Re: accessing encrypted USB device
do not slay Fsys.umass, just rm /dev/hd1 and it should terminate by itself.
Regards, PKY
Doesn't seem to.  I tried
# rm /dev/hd1
but Fsys.umass keeps running.
If I now slay Fsys.umass and restart it, I still get the same error.
Are there any partitions on the drive?
output of " ls -l /dev/hd1* " shows only /dev/hd1?
Regards, PKY
> # rm /dev/hd1
No.  Running fdisk on /dev/hd1 shows no partitions of any type.
Incidentally, I tried the same sequence on a regular unencrypted disk and got the same results
(i.e., Fsys.umass does not go away if the device is removed, and if killed manually cannot be
restarted).
Hi William,
Please, post here output of following command. Launch it 1) before
starting Fsys.umass, 2) after this and 3) after slaying Fsys.umass and
removing /dev/hd1:
# ls -l /dev
It seems like several USB mass storage devices are present in your system.
> and got the same results (i.e., Fsys.umass does not go away if the
> device is removed, and if killed manually cannot be restarted).
> QNX4 Community Support
> http://community.qnx.com/sf/go/post84690
> Hi William,
> removing /dev/hd1:
> # ls -l /dev
I don't see that, but here's the output:
### After running io-usb:
total 3582371
brw-------  1 root      root         2,   1 Dec 31  1969 cd0
crw--w--w-  1 root      root         5,   1 Apr 08 13:28 con1
crw--w--w-  1 root      root         5,   2 Apr 08 13:19 con2
crw-rw-rw-  1 root      root         5,   3 Apr 08 13:13 con3
crw-rw-rw-  1 root      root         5,   4 Apr 08 13:13 con4
crw-rw-rw-  1 root      root         5,   5 Apr 08 13:13 con5
crw-rw-rw-  1 root      root         5,   6 Apr 08 13:13 con6
brw-------  1 root      root         2,   2 Dec 31  1969 hd0
brw-------  1 root      root         2,   3 Dec 31  1969 hd0t77
brw-------  1 root      root         2,   4 Dec 31  1969 hd0t78
crw-------  1 root      root         6,   1 Apr 08 13:13 kbd
crw-rw-rw-  1 root      root         4,   1 Apr 08 13:13 null
crw-rw-rw-  1 root      root         8,   1 Apr 08 13:13 par1
crw-rw-rw-  1 root      root         9,   1 Apr 08 13:13 ptyp0
crw-rw-rw-  1 root      root         9,   2 Apr 08 13:13 ptyp1
crw-rw-rw-  1 root      root         9,   3 Apr 08 13:13 ptyp2
crw-rw-rw-  1 root      root         9,   4 Apr 08 13:13 ptyp3
crw-rw-rw-  1 root      root         7,   1 Apr 08 13:13 ser1
crw-rw-rw-  1 root      root         7,   2 Apr 08 13:13 ser2
drwxrwxrwt  2 root      root              0 Dec 31  1969 shmem
crw-rw-rw-  1 root      root        10,   1 Apr 08 13:13 ttyp0
crw-rw-rw-  1 root      root        10,   2 Apr 08 13:13 ttyp1
crw-rw-rw-  1 root      root        10,   3 Apr 08 13:13 ttyp2
crw-rw-rw-  1 root      root        10,   4 Apr 08 13:13 ttyp3
cr--r--r--  1 root      root        13,   0 Apr 08 13:28 usb
### After running Fsys.umass:
total 6945063
brw-------  1 root      root        14,   7 Apr 08 13:28 cd1
brw-------  1 root      root        14,   8 Apr 08 13:28 hd1
### After slaying Fsys.umass and removing /dev/hd1:
total 4032935
crw--w--w-  1 root      root         5,   1 Apr 08 13:28...
William,
Cd1 device is also appeared. Do you have USB CD-ROM plugged? If so then
you have to remove /dev/cd1 as well as /dev/hd1. Please note that you have
to remove all devices which have been created by Fsys.umass before
restarting the driver.
> > Hi William,
> > # ls -l /dev
> > system.
> total 3582371
> total 6945063
> drwxrwxrwt  2 root      root  ...
> William,
No USB CD, *but* apparently the read-only portion of the encrypted disk shows
up as a CD, which I didn't notice before!  So, removing the "CD" allows Fsys.umass
to be restarted.  Thanks a lot!
William
