Trackers
Trackers
Forum Topic - Bug in QNX4 grep?: Page 1 of 8 (8 Items)
Bug in QNX4 grep?
I'm trying to build a package on QNX4 using the configure script built with autoconf 2.65 but it fails. I've tracked it
down to what appears to be a bug in the QNX supplied grep.
The command that is failing is effectively:
grep -c '$'
This is supposed to count the number of end-of-lines in the input stream but always returns 0.
An example of usage:
cat /etc/hosts | grep -c '$'
will return 0 on QNX4, but works fine on Linux.
cat /etc/hosts | grep -c '^'
successfully returns the number of start-of-lines on QNX4 and Linux, so I conclude that there is a bug in the supplied
grep.
As the use of grep -c '$' is embedded in the generated configure script I can change the configure script but that's not
 an ideal solution. It will affect every other source package distributed that uses autoconf, not just the ones that I
maintain.
Is there any chance that this bug in grep could be rectified? (This is the most effective solution)
Is there a port of GNU grep for QNX4? (This is also not ideal as it would require installation of another package)
I will try and see if the autoconf maintainers will make a change to work around this bug.
Thanks for reading this far.
Mark
