Trackers
Trackers
Forum Topic - ohci-mgt5200 on USB port 2: (1 Item)
I've a board with usb port on USB Port1  on MPC5200B processor; I use the following command to start the ohci driver:
/sbin/io-usb -dohci-mgt5200 ioport=0xf0001000,irq=70
and the driver works fine.
Now I've another board whith USB cabled on USB Port2 (one of PSC3 pin group) and I use the same command to start the
ohci driver but it doesn't work.
Is it correct to use the same sintax for USB port2? the irq=70 is valid also for usb port 2?
thank you
Massimo
