Yegnesh S
04/28/2009 2:05 AM
post28214
I have downloaded the QNX source.
I have installed qnxsdp-6.4.0-200810211530-linux.bin in an RHEL4
machine.
This is the build environment I am using.
My source contains:
1. lib
2. services
3. ports
4. utils
5. hardware - downloaded separately.
Further to this I did the steps listed as follows.
1. ksh hide-gnu.sh <BUILD_ROOT>
2. cd <BUILD_ROOT>
3. mkdir stage
4. cat >qconf-override.mk
USE_INSTALL_ROOT=1
INSTALL_ROOT_nto=<BUILD_ROOT>/stage
VERSION_REL=6.3.0
^D
5. export QCONF_OVERRIDE=<BUILD_ROOT>/qconf-override.mk
6. cd <BUILD_ROOT>/trunk
7. make OSLIST=nto hinstall
8. make OSLIST=nto CPULIST=x86 install
When I follow these steps, I get the following errors:-
/home/yegnesh/QNX/trunk/hardware/deva/ctrl/mpc5121_i2s/mpc5121ado.h:32:2
0: error: hw/dma.h: No such file or directory
In file included from
/home/yegnesh/QNX/trunk/hardware/deva/ctrl/mpc5121_i2s/mpc5121_dll.c:23:
/home/yegnesh/QNX/trunk/hardware/deva/ctrl/mpc5121_i2s/mpc5121ado.h:57:
error: expected specifier-qualifier-list before 'dma_functions_t'
/home/yegnesh/QNX/trunk/hardware/deva/ctrl/mpc5121_i2s/mpc5121_dll.c: In
function 'mpc5121_capabilities':
/home/yegnesh/QNX/trunk/hardware/deva/ctrl/mpc5121_i2s/mpc5121_dll.c:87:
error: 'struct mpc5121_card' has no member named 'pcm_chn'
/home/yegnesh/QNX/trunk/hardware/deva/ctrl/mpc5121_i2s/mpc5121_dll.c:89:
function 'mpc5121_playback_aquire':
/home/yegnesh/QNX/trunk/hardware/deva/ctrl/mpc5121_i2s/mpc5121_dll.c:112
: error: 'dma_addr_t' undeclared (first use in this function)
: error: (Each undeclared identifier is reported only once
: error: for each function it appears in.)
: error: expected ';' before 'src_addr'
/home/yegnesh/QNX/trunk/hardware/deva/ctrl/mpc5121_i2s/mpc5121_dll.c:113
: error: 'dma_transfer_t' undeclared (first use in this function)
: error: expected ';' before 'tinfo'
/home/yegnesh/QNX/trunk/hardware/deva/ctrl/mpc5121_i2s/mpc5121_dll.c:117
: error: 'struct mpc5121_card' has no member named 'pcm_chn'
/home/yegnesh/QNX/trunk/hardware/deva/ctrl/mpc5121_i2s/mpc5121_dll.c:135
: error: 'tinfo' undeclared (first use in this function)
Attached is the compile logs.
It would be of great help if someone can point out what am I doing
wrong.
Thanks & Regards,
Yegnesh
Please do not print this email unless it is absolutely necessary.
The information contained in this electronic message and any attachments to this message are intended for the exclusive
use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended
recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy
all copies of this message and any attachments.
WARNING: Computer viruses can be transmitted via email. The recipient should check this email and any attachments for
the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email.
www.wipro.com
