Trackers
Trackers
Forum Topic - USB to Serial Port Converter: (7 Items)
Hi everybody,
I am using a convertor by Silicon Labs company for converting RS485 to USB. After some researching, i learned i must run
 devc-serusb in order to create a IO file for my converter, such as /dev/serusb1. My QNX didn't contains devc-serusb
executable driver file, but i transffered it from Windows to QNX via SSH, put into /sbin directory, applied chmod
command to run it. Now, i can run devc-serusb but it doesn't create a IO file in dev directory, no /dev/serusbX file.
The converter is listed by usb (-vvv) command, i see its vid, did, bus, devno etc. When i use commands in http://www.qnx
.com/support/knowledgebase.html?id=50130000000mttO, devc-serusb doesn't run at this time. Obviously, i failed :(
Can you help me about how i can?
Best regards,
Orcun.
Re: USB to Serial Port Converter
hi again,
i solved the problem, it arised from devc-serusb file in qnx sdk directory in my windows, i changed my devc-serusb with
devc-serusb file of another qnx os. these files sizes are not same but they are files of same version (QNX 6.5). one of
them was installed from qnx 6.5 cd, other one was installed from downloaded exe file from qnx web site. i think this may
 be more serious problem. despite it was solved i wonder, i will be happy if anybody can explain the problem.
best regards,
orcun.
can you attach both files: the one that didn't work and the one that did
work?
On 14-03-17 11:16 AM, B. Orcun OZKABLAN wrote:
> hi again,
with devc-serusb file of another qnx os. these files sizes are not same but they are files of same version (QNX 6.5).
one of them was installed from qnx 6.5 cd, other one was installed from downloaded exe file from qnx web site. i think
this may be more serious problem. despite it was solved i wonder, i will be happy if anybody can explain the problem.
> best regards,
> orcun.
> http://community.qnx.com/sf/go/post109453
> To cancel your subscription to this discussion, please e-mail general-community-unsubscribe@community.qnx.com
this file works, its size is 138.022 byte.
http://www.speedyshare.com/MmWdA/devc-serusb
this is one which not works, size is 121.104 byte.
http://www.speedyshare.com/FST8e/devc-serusb
i uploaded from windows, so chmod may be necessary.
The working one is from 6.5.0SP1, the not working one is from 6.5.0
/tmp/forum$ ls -l
total 264
-rw-r--r-- 1 aristovski aristovski 138022 Mar 17 11:35 devc-serusb.1
-rw-r--r-- 1 aristovski aristovski 121104 Mar 17 11:36 devc-serusb.2
/tmp/forum$ use -i ./devc-serusb.1
NAME=devc-serusb
DESCRIPTION=USB serial class device driver for the USB-to-Serial adapters
DATE=2012/06/20-13:41:31-EDT
STATE=stable
HOST=gusbuild4
USER=builder
VERSION=6.5.0
TAGID=650SP1-166
/tmp/forum$ use -i ./devc-serusb.2
NAME=devc-serusb
DATE=2010/07/09-13:55:35-EDT
STATE=stable
HOST=mainbuild
USER=builder
VERSION=6.5.0
TAGID=89
There have been changes to devc-serusb between 6.5.0 and 6.5.0SP1:
From: http://www.qnx.com/developers/articles/rel_5189_3.html
What's new: Character drivers (devc-*)
devc-serusb
     This driver now supports these devices:
         Cinterion AHx module (Ref# 124687, 142316)
         Sierra Wireless AR8550 3G dongle (Ref# 117569, 142488)
     as well as the following features:
         CDC ACM; the driver automatically detects ACM devices, based on
the USB Class code (Ref# 68333, 80267, 142175)
         a DCMD_CHR_RESET devctl() command that resets the device (but
not all drivers use this command) (Ref# 80267, 142175)
         a drt option that lets you specify the data-ready timeout (Ref#
116850, 142306)
> http://community.qnx.com/sf/go/post109456
Thank you so much Aleksandar, i will be more careful about version anymore.
