Trackers
Trackers
Forum Topic - The cause of porting as colliding GPL.: (2 Items)
Thanks Boudreau and Mathew
So we need another porting one of dd utility.
and, Have we able to use the bmake on QNX6.4.0?
Regards.
Kengo Kinoshita
----- Original Message -----
>On Wed, Aug 04, 2010 at 04:33:47AM -0400, Kengo Kinoshita wrote:
>> Hello
>> I am Japanese software engineer.
>> Now I begin to start the porting job that porting dd utility from NetBSD to QNX6.4.0.
>I guess the first question is why do you want to
>port the NetBSD one?  What's wrong with the
>shipped dd?
>> and Source code of dd(NetBSD edition) was already downloaded and already try to rebuild on QNX6.4.0.
>> But many errors happen,
>> So I am very confused those errors are see bellow(used Makefile)
>> Makefile:7: *** missing separator.
>NetBSD uses bsd make (bmake), not gnu make.
>> and simply gcc using as bellow.
>> Please teach me something solve operations regarding the porting job.
>> # gcc dd.c -o dd
>> In file included from /root/NetBSD/usr/src/include/rpc/types.h:41,
>>                  from /root/NetBSD/usr/src/sys/sys/mtio.h:37,
>>                  from dd.c:53:
>> /root/NetBSD/usr/src/sys/arch/hpc/stand/include/machine/types.h:21: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'int64_t'
>> /root/NetBSD/usr/src/sys/arch/hpc/stand/include/machine/types.h:26: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'uint64_t'
>> /root/NetBSD/usr/src/sys/arch/hpc/stand/include/machine/types.h:32: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'u_int64_t'
>> /root/NetBSD/usr/src/sys/arch/hpc/stand/include/machine/types.h:38: error: conflicting types for 'time_t'
>> /usr/qnx640/target/qnx6/usr/include/time.h:46: error: previous declaration of 'time_t' was here
>> In file included from dd.c:66:
>> dd.h:45: error: expected specifier-qualifier-list before 'uint64_t'
>> dd.h:61: error: expected specifier-qualifier-list before 'uint64_t'
>> In file included from dd.c:67:
>> extern.h:58: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'cpy_cnt'
>> extern.h:59: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'cbsz'
>> extern.h:62: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'progress'
>> dd.c:80: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'cpy_cnt'
>> dd.c:83: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'cbsz'
>> dd.c:85: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'progress'
>> dd.c: In function 'main':
>> dd.c:107: error: 'SIGINFO' undeclared (first use in this function)
>> dd.c:107: error: (Each undeclared identifier is reported only once
>> dd.c:107: error: for each function it appears in.)
>> dd.c: In function 'setup':
>> dd.c:126: error: 'IO' has no member named 'name'
>> dd.c:127: error: 'IO' has no member named 'name'
>> dd.c:128: error: 'IO' has no member named 'fd'
>> dd.c:130: error: 'IO' has no member named 'fd'
>> dd.c:130: error: 'IO' has no member named 'name'
>> dd.c:131: error: 'IO' has no member named 'fd'
>> dd.c:132: error: 'IO' has no member named 'name'
>> dd.c:136: error: 'IO' has no member named 'fd'
>> dd.c:141: error: 'IO' has no member named 'flags'
>> dd.c:146: error: 'IO' has no member named 'name'
>> dd.c:148: error: 'IO' has no member named 'fd'
>> dd.c:149: error: 'IO' has no member named 'name'
>> dd.c:153: error: 'IO' has no member named 'fd'
>> dd.c:153: error: 'IO' has no member named...
Re: The cause of porting as colliding GPL.
Attached is a NetBSD dd ported to our makefile
structure.  Tape support is disabled.  Grep
for __QNXNTO__ for the diffs.  Test as you feel
appropriate.
You can get one if you bootstrap pkgsrc but there's
other issues (see attached archive).
http://community.qnx.com/sf/projects/pkgsrc
Attachment: Text dd.tgz 20.06 KB
