Trackers
Trackers
Forum Topic - io-pkt-v4 crash when nw_pthread_create() used.: (1 Item)
Hi iam working of QNX 641 for ppc target.using io-net driver with shim layer.
We have developed a module which broadcast raw ethernet packets.
which is working fine.
When i include the functionality of broadcasting in nw_pthread_create() function io-pkt is getting crashed.
i am creating the thread as follows.
if (nw_pthread_create( NULL, NULL, send_qnet_broadcast, NULL,WT_FLOW,nr_nwthread_init,NULL) != EOK) {
		slogf(_SLOGC_RESOLVER, _SLOG_CRITICAL,"nw_pthrad_create() failed");
		return 0;
the nr_nwthread_init() function is as follows.
static int nr_nwthread_init(void * arg)
	struct nw_work_thread	*wtp;
	slogf(_SLOGC_RESOLVER, _SLOG_CRITICAL, "nr_nwthread_init");
	wtp = WTP;
	wtp->intr_sighot = 1;
	wtp->wt_zone_mbuf.max = mbuf_cache_max;
	wtp->wt_zone_packet.max = pkt_cache_max;
	wtp->quiesce_callout = NULL;
	wtp->quiesce_arg = NULL;
	slogf(_SLOGC_RESOLVER, _SLOG_CRITICAL, "nr_nwthread_init end");
	return EOK;
what else iam missing out??
Why io-pkt-v4 is getting crashed??
is there an detailed documentation about how to use nw_pthread_create() ??
How to set its attributes??
Let me know?
