Trackers
Trackers
Forum Topic - Error with *.use file - spawn ldrel: Invalid argument: (2 Items)
I have a project with multiple processes. Each process has a use file in it. When i try to build in QNX 6.4.1 (GCC 4.3.
3), the first process with a *.use file gives the following error:
"spawn ldrel: Invalid argument"
If I build again, then the same error appears but now it is pointing to the *.use file of the 2nd process (*.use file of
 the 1st process does not give errors now, this is probably because object files and the process exe for the 1st process
 were built in the first build).
When I repeat this enough number of times, all the *.use errors vanish. However, if I do a clean and then try to build,
then the error starts appearing from the 1st project and continues in the same cycle.
How do I overcome this error?
Another information is that, my project was initially built on QNX 6.3 and now I am trying to migrate it it QNX 6.4.1
(GCC 4.3.3)
Please provide any information that will help me build my files on QNX 6.4.1 without any issues.
Sunil Keshava
Re: Error with *.use file - spawn ldrel: Invalid argument
I have tried to uninstall and reinstall QNX 641 on my PC. But the issue persists. I am running out of ideas to solve
this issue.
Is there a way to raise this issue to a higher level?
Sunil
