Trackers
Trackers
Forum Topic - promiscuous mode in QNX 6.41 on x86 platform: (3 Items)
I have a problem with promiscuous mode in QNX 6.41 on x86 platform.
When I use devn-rtl8169.so (from QNX 6.40 instalation) everything is OK - promiscuous mode works.
In file /etc/system/enum/devices/net is
mount(-Tio-pkt "-opci=$(index),vid=0x$(ven),did=0x$(dev)" /lib/dll/devn-rtl8169.so, "/dev/io-net/en$(netnum)")
When I use devnp-rtl8169.so promiscuous mode doesn't work.
mount(-Tio-pkt "-opci=$(index),vid=0x$(ven),did=0x$(dev)" /lib/dll/devnp-rtl8169.so, "/dev/io-net/en$(netnum)")
As an interface I use libpcap.a library. All src code is below.
It seems that new drivers devnp* make device rt0 and promiscuous mode doesn't work.
Is this only termporary phase (there are devn* and devnp* drivers in instalation) or promiscuous mode won't be suported
any more?
Or should I set promiscuous mode in other way? (pcap_open_live - the third parameter is set to 1)
Pavel Šimek
//all src code
#include <sys/neutrino.h>	// #define _NTO_VERSION
#include <pcap.h>
int main()
    pcap_if_t *alldevs;
    pcap_if_t *d;
    int inum;
    int i=0;
    pcap_t *adhandle;
    int res;
    char errbuf[PCAP_ERRBUF_SIZE];
    struct tm *ltime;
    char timestr[16];
    struct pcap_pkthdr *header;
    const u_char *pkt_data;
    if(pcap_findalldevs(&alldevs, errbuf) == -1){
      fprintf(stderr,"Error in pcap_findalldevs: %s\n", errbuf);
      return -1;
    /* Print the list */
    for(d=alldevs; d; d=d->next)
        printf("%d. %s", ++i, d->name);
        if (d->description)
            printf(" (%s)\n", d->description);
        else
            printf(" (No description available)\n");
    if(i==0)
        printf("\nNo interfaces found! Make sure WinPcap is installed.\n");
        return -1;
    printf("Enter the interface number (1-%d):",i);
    scanf("%d", &inum);
    if(inum < 1 || inum > i)
        printf("\nInterface number out of range.\n");
        /* Free the device list */
        pcap_freealldevs(alldevs);
        return -1;
    /* Jump to the selected adapter */
    for(d=alldevs, i=0; i< inum-1 ;d=d->next, i++);
    	/* Open the adapter */
        if ((adhandle= pcap_open_live(d->name, 65536, 1 /* nonzero promiscuous*/, 100, errbuf )) == NULL)
            fprintf(stderr,"\nUnable to open the adapter. %s is not supported by WinPcap\n", d->name);
		return -1;
    printf("\nlistening on %s...QNX:%d\n", d->name, _NTO_VERSION);
        /* At this point, we don't need any more the device list. Free it */
	/* Retrieve the packets */
    while((res = pcap_next_ex( adhandle, &header, &pkt_data)) >= 0){
            if(res == 0)
                continue;
            /* convert the timestamp to readable format */
            ltime=localtime(&header->ts.tv_sec);
            strftime( timestr, sizeof timestr, "%H:%M:%S", ltime);
            printf("%s,%.6d len:%d\n", timestr, header->ts.tv_usec, header->len);
    if(res == -1){
        printf("Error reading the packets: %s\n", pcap_geterr(adhandle));
        return -1;
    pcap_close(adhandle);
    return 0;
Re: promiscuous mode in QNX 6.41 on x86 platform
check this one:
http://community.qnx.com/sf/discussion/do/listPosts/projects.networking/discussion.general.topc9917
Jeevan
Thanks for your reply.
When I run denvp-rlt8169 this way
mount -T io-pkt -opci=0,vid=0x10ec,did=0x8167,promiscuous "/lib/dll/devnp-rtl8169.so" "/dev/io-net/rt0
Another problem occurs when I set up IP address on this device. Promiscuous mode (on tr0) is set off. On en1 device
(devn* driver) is on.
Is it a bug or I should do something in other way to run devnp* driver in  promiscuous mode and with tcpip?
Pavel Simek
